AoS The new Battletome: A Discussion
Discussion in 'Seraphon Discussion' started by sigmonstar, Mar 2, 2020.
Are you optimistic about our new battletome?
  1. Yes
    160 vote(s)
    76.2%
  2. No
    20 vote(s)
    9.5%
  3. Undecided
    30 vote(s)
    14.3%
  1. Alladin the Paladin
    Best thing I read all day.
    Dread Saurian and Lizerd like this.
  2. Lizerd
    Lizerd Well-Known Member
    My question is how are you able to monetarily afford 3 dread saurian? That’s worth about as much as most of the armies I run
  3. Alladin the Paladin
    The better question is why don’t you own a Dread Saurian being ridden by a Carnasaur, who is being ridden by an Old Blood.
    Like a Turducken, but Dreacarnlood
  4. Dread Saurian
    I bought 1 a year for the past 3 years. Putting away a little bit for minis and splurging when I get my tax return so usually I use 100 out of my tax return plus what I put away to buy a fuckload of minis and a dread saurian.
  5. Dread Saurian
    It is a bit goofy but id run it
    Imrahil, Carnikang and Lizerd like this.
  6. Lizerd
    Challenge accepted
  7. Alladin the Paladin
    Sotekspeed, soldier
  8. Cuetzpal Pilli
    Cuetzpal Pilli Well-Known Member
    Sorry to pour more salt on the wound, but this isn't playable as Thunder Lizards is strictly a Coalesced sub-faction and therefore don't have access to summoning.
    Carnikang likes this.
  9. Carnikang
    Carnikang Well-Known Member
    TBF, if they are near a Slann, you can get at least 10 Sauras Warriors a turn (hopefully) for summoning. Maybe more, depending on the FAQ on their ability.
    10 sauras a turn is actually very fast compared to the assumed 3-9 CCP you can get in one turn bare minimum as Starborne. that may be 10 skinks, but you honestly want 10 CCP for Sauras, so it's a turn 2 summon on turn 1....
    This could be interesting. Again, depending on the FAQ.
    Canas and Cuetzpal Pilli like this.
  10. Steve
    Steve Member
    Just a question to the group (sorry if this has mentioned previously). Looking at the rules in the battle tome, if you go for skinks with javalins you dont get a close combat attack? And you cant equip shields to them?
  11. Grotpunter
    Grotpunter Well-Known Member
    I think his point was that having multiple EotG in Coalesced to summon Saurus Warriors is a better summoning mechanic than going Starborne and collecting CCP to summon Saurus Warriors.
    You have 2 options for both Boltspitters and Meteoric Javelins. Either you equip them with Moonstone Clubs (better in melee) or with a Celesite Dagger + Starbuckler (worse in melee but gives a 5+ save).
    Cuetzpal Pilli likes this.
  12. Killer Angel
    :D:D:D
  13. Killer Angel
    The summoning for coalesced is "granted" by the EotG. It's not guaranteed, but it's something.
  14. Steve
    Steve Member
    You have 2 options for both Boltspitters and Meteoric Javelins. Either you equip them with Moonstone Clubs (better in melee) or with a Celesite Dagger + Starbuckler (worse in melee but gives a 5+ save).[/QUOTE]
    Thank you now makes sense. I was reading as they were all separate options
  15. Nart
    Nart Well-Known Member
    By the way, does Thunder Lizard's CA allow multiple EotG to be launched at the same turn?
  16. Alladin the Paladin
    Pretty sure the answer is no...
  17. Killer Angel
    YES, but you need to use multiple command points and you must use the ability each time on a different EotG. So, 3 EotG = 3CA
    Just A Skink and Nart like this.
  18. Alladin the Paladin
    Ahh I see, RAW, you can only use the Engine once per shooting phase, but with the CA you can activate additional engines once.
  19. Nart
    At least, owner of multiple EotGs doesn't have to remake them.
  20. Canas
    this is also a weird thing about summoning. Why in the world does the EoTG pump out units quicker than several freaking slannput together.It is such a weird mechanic now.
    Just A Skink and Carnikang like this.
