Helas Guys I m new here and "new" in Age of Sigmar, i love this Game, but i allways loose against Slaanesh ;( So i hope you can help me and maybe you can make with my Units a better Armylist against Slaanesh. And maybe you can tell me a Tactic against Slaanesh. My units are: 1x Lord Kroak 1x Saurus Oldblood auf Carnosaur 1x Troglodon 1x Bastiladon 1x Saurus Astrolith Bearer 1x Skink Starpriest 1x Saurus Oldblood 16x Saurus Knights 86x Saurus Warriors 91x Skinks 5x Chamelen Skinks Thank you for your help.
My advice is to block his charges with speed bump units of 10 skinks.. Slaanesh is a glass cannon. If you can tie up his big hitters and then counter charge them you will be much more effective.
Your units are in a bit of akward situtaion. If you are allowed to run as proxies then there are a number options that open up. For instance, Saurus Warrior are better when there is a Sunblood near by them intead of an Oldblood. Lord Kroak is too point heavy for 1k, but Slanns are perfect. If you had 6 Rippers we could build a mean 1k Shadowstrike. Your best bet using only what you own as it is built would be to run a Skink Heavy list. At least 2 units of 40 Skinks with a Sauru Astrolith Bearer to grant them Proud Defiance. Chameleon Skinks really begin to shine in units of 10 when they are able to pose a viable threat to back-line support. Even still, I would bring them. They can roadblock some Demonettes or Seekers of Slanesh if they fail their assassination assignments. I will spend time with your units and work on a more concrete list after I finish some real life things. Best of luck!
great, thx for your answere. I still plan to buy some units: Rippers, razordon, one more bastiladons and 1-2 engine of the gods for a "normal" slaan i can use my lord kroak as a slaan starmaster, so i dont must buy a another modell ;D i will make a Thunderquake Starhost List like this: Engine of the Gods (220) Engine of the Gods (220) Engine of the Gods (220) Engine of the Gods (220) Lord Kroak (450) UNITS 40 x Skinks (240) -Boltspitters & Star Bucklers 20 x Skinks (120) -Meteoric Javelins & Star Bucklers 10 x Skinks (60) -Meteoric Javelins & Star Bucklers 3 x Skink Handlers (40) 2 x Razordons (80) BATTALIONS Thunderquake Starhost (120) TOTAL: 1990/200 or: Slann Starmaster (260) - General - Command Trait : Arcane Might - Artefact : Prism of Amyntok Engine of the Gods (220) - Artefact : Coronal Shield Saurus Astrolith Bearer (160) UNITS 2 x Razordons (80) 3 x Skink Handlers (40) 40 x Skinks (240) -Boltspitters & Star Bucklers 40 x Skinks (240) -Meteoric Javelins & Star Bucklers 10 x Skinks (60) -Boltspitters & Star Bucklers BEHEMOTHS Bastiladon (280) Bastiladon (280) BATTALIONS Thunderquake Starhost (120) TOTAL: 1980/2000 but I do not know if these lists are good to play.
Sadly, for your first list, EotGs do not count as keyword Steggadon for the purpose of Thunderquake Starhost. The second list look good though.
