AoS 1K list : Need some advice
Discussion in 'Seraphon Army Lists' started by Koriialstraz, Sep 17, 2018.
  1. Koriialstraz
    Koriialstraz Well-Known Member
    Hi mates,
    This weekend, I'll play some games and we decide to play with 1K list.
    We won't use the realms rules but we can use endless spell.
    So I would like to know what lists can I play with the model I currently have.
    Thank you all for the help, I'm very bad at lists building since I want to put everything but can't and so, I don't know what to play.
    Engine of the gods
    Slann starmaster
    Skink priest
    Skink starpriest
    Saurus eternity warden
    Saurus astrolith bearer
    Saurus oldblood on carnosaur
    Saurus scar-veteran on cold one
    Saurus sunblood
    Bastiladon (I can use each type)
    Chameleon skinks (x5)
    Ripperdactyl riders (x3)
    Salamenders
    Skinks handlers (x3)
    Saurus guard (x15)
    Saurus knights (x7)
    Saurus warriors (x11)
    Skinks (x40)
    All the endless spells
  2. LizardWizard
    Your list could look something like this:
    Allegiance: Seraphon
    LEADERS:
    Slann Starmaster
    (260)
    - General
    - Command Trait : Great Rememberer
    Saurus Astrolith Bearer (160)
    Skink Starpriest (80)
    Engine of the Gods (220)
    UNITS:
    10 x Skinks (60)
    -Boltspitters & Star Bucklers
    10 x Skinks (60)
    1 x Salamanders (40)
    ENDLESS SPELLS:
    Balewind Vortex
    (40)
    Chronomantic Cogs (60)
    980/1000
    Turn one you want to get the Balewind Vortext up and have your Skink Starpriest cast Cogs for your Slann as well. This means you won't be getting Summon Starlight off until your second turn and will leave you slightly vulnerable until then. This list has no real firepower on its own, and you will want to be summoning on Skinks and your bigboy dinos asap. Normally I would drop the EotGs in order to have at least one 40 man blob of Skinks and some Razordons. Should your EotGs roll 14-17 on turn 1 then I recommend summoning your Rippers to the field to allow for Bloat Toad placement and to apply pressure on your opponent's more vulnerable heroes or any glass-cannon units they field.
    The main weakness of this list is that you are forced to play a reactionary game. It is still probably better than trying to turtle behind an Eternal Starhost though.
    I hope this is helpful. Best of luck in your match.
    Koriialstraz and Crowsfoot like this.
  3. Koriialstraz
    Of course it's helpful ! Thanks for this !
    I think that I'll try with this one.
    For me, every ideas, advice are helpful. Because, nobody is thinking in the same way, so more opinion = more options ! :D
  4. Crowsfoot
    A really risky list
    Leaders
    Slann Starmaster (260)
    - General
    - Trait: Great Rememberer
    - Artefact: Prism of Amyntok
    Battleline
    30 x Skinks (180)
    10 x Skinks (60)
    Units
    3 x Ripperdactyl Riders (140)
    Battalions
    Shadowstrike Starhost (180)
    Endless Spells
    Balewind Vortex (40)
    Total: 1000 / 1000
    Extra Command Points: 1
    Allies: 0 / 200
    Wounds: 60
    Use the Slann as a summoning machine, use the rippers to take out threats first turn.
    Koriialstraz likes this.
  5. Koriialstraz
    I can try it too.
    I think that we'll do more than one match, we are 6 players.
    The others play, Sylvaneth, Skaven, Death, Slave to Darkness, Kharadron Overlords and mix Order (essentially old high elves).
    So I think that I'll prepare several lists and try to take the one that seems more appropriate for the battle.
  6. LizardWizard
    I love 1k Shadowstrike. Normally I run mine without a SLann and run a unit of 6 RIppers and 4 Razordons. @Crowsfoot version definitely works too. Against the armies you just listed above I would run Shadowstrike instead of the Summon list I provided. S2D, Sylvaneth, & Skaven are all ideal target for Shadowstrike because they all rely on key units to generate their synergies. You can severely hamstring their army with some well placed Rippers.
  7. Koriialstraz
    I'll keep that in mind :D
  8. gmoney
    gmoney Member
    There are a few lists in a 1k thread I've made:
    This one is by Aginor
    Leaders
    - general, some artefact to keep him alive
    Battleline
    40 x Skinks (240)
    10 x Skinks (60)
    Units
    6 x Terradon Riders (240)
    - Sunleech Bolas
    Battalions
    Endless Spells
    Geminids of Uhl-Gysh (40)
    Total: 1000 / 1000
    Allies: 0 / 200
    Wounds: 78
    Gank enemies with skinks and terradons then kite afterwards. I plan to run a riskier list with rippers instead of terradons and chamos instead of the astro.
  9. gmoney
    gmoney Member
    I'm also planning to run a pseudo eternal starhost build:
    Leader
    Engine of the Gods [220pts]
    Saurus Astrolith Bearer [160pts]
    Slann Starmaster [260pts]
    Battleline
    Saurus Guard [270pts]: 3x 5 Saurus Guard
    Skinks [60pts]: 10 Skinks, Boltspitters and Moonstone Clubs
    You can find a bunch more lists here: http://www.lustria-online.com/threads/all-around-best-1k-army-list.21843/
  10. Koriialstraz
    Thanks for the list and the link. I read a little this thread, but I wanted to make one with the list of my current model, as I can't buy other for the moment (my wallet really don't want that). So, with this list, all good people can give me some pretty good advice with what I have at my disposition.
    For example, the first list you gave me, I can't play it, as I don't have everything.
  11. gmoney
    gmoney Member
    My bad. Killer Angel did post the teleporting razordons (which you can proxy with your sallies assuming you have 3 or 4) or the teleporting stegadon (which you can proxy with EotG) lists which seem pretty strong.
  12. gmoney
    gmoney Member
    @LizardWizard Bruh you posted your shadowstrike build and I don't see no razors here don't be lying to my mans kori
    LEADERS:
    Skink Starpriest
    (80)
    - General
    - Command Trait : Master of Star Rituals
    - Artefact : Light of Dracothion
    UNITS:
    6 x Ripperdactyl Riders (280)
    40 x Skinks (180)
    30 x Skinks (240)
    BATTALIONS:
    TOTAL: 960/1000
    FYI you mixed the points between the 2 units of skinks :p
  13. Koriialstraz
    I only have one sallie ^^
    And I don't have any razordon yet. So that's why he can't put any in a list made for me :D
  14. LizardWizard
    It just depends what people own. This is my favorite 1k list:
    LEADERS:
    Skink Starpriest
    (80)
    - General
    - Artefact : Incandescent Rectrices
    UNITS:
    4 x Razordons (160)
    40 x Skinks (240)
    10 x Skinks (60)
    BATTALIONS:
    (180)
    TOTAL: 1000/1000 EXTRA COMMAND POINTS: 1
    It is not very beginner friendly. You need a deep knowledge of other armies to be able to wield it effectively. Ideally you will be able to keep your Rippers mobile and on the hunt. I have played more than one 1k game at events where I essentially tabled all my opponent's threats turn one. Most 1k list are not 2 drops and even fewer have the body count to zone you out of the alpha strike.
  15. Koriialstraz
    So I played 2 games yesterday and choose for both games the list that @Crowsfoot tell me.
    I loose the first one, it was against a legion of Nagash. And I win the second one against slave to darkness.
    I wanted to write down a battle rep, but I forget to take note and I was at a weeding yesterday night, so I don't remember all the details.
    But it was fun games !
  16. DeathBringer125
    Congrats! FOR THE SERAPHON!!!
  17. GuaDan
    GuaDan Well-Known Member
    Is it really worth it go summoning in a 1k shadowstrike?
  18. LizardWizard
    I don't bother with summoning for 1k Shadowstrike. I find that I am reliably able to kill off my opponents threats turn one.
  19. GuaDan
    My experience is more than limited, but I'm pretty sure Shadowstrike is very glass-cannon oriented.
    Giving these guys something to defend (the Slann) without being able to, and less 1st turn damage can really clip their wings.
  20. DeathBringer125
    Yes but using Slann in shadowstrike could actually work very well (from my assumptions I’ve never played shadowstrike lol). Because the mortal wounds could chip away at them and also because when they have guys coming from behind them they will divert attention so you won’t need as much protection for them especially if you turtle them.
