AoS 2.5 Dracothion's Tail/Eternal Starhost
Discussion in 'Seraphon Army Lists' started by Jeddaven, Sep 12, 2017.
  1. Jeddaven
    Jeddaven New Member
    This is my first real Seraphon list, which I put together using Warscroll Builder. I'm not really sure about which artefacts I want to give my heroes, and I expect to be going up against a wide variety of armies at my local store, though that will include a large number of Skaven. I know of at least two Skyre-heavy armies, and another that's more mixed.
    Allegiance: Seraphon
    Leaders
    Slann Starmaster (260)
    - General
    - Command Trait : Vast Intellect
    Saurus Scar-Veteran on Carnosaur (240)
    - Warblade
    Engine of the Gods (220)
    Saurus Oldblood on Carnosaur (280)
    Saurus Eternity Warden (140)
    - Artefact : Coronal Shield
    Skink Starpriest (80)
    Units
    10 x Saurus Guard (200)
    5 x Saurus Knights (100)
    -Lances
    -Lances
    -Lances
    Behemoths
    Bastiladon (280)
    -Solar Engine
    Battalions
    Dracothion's Tail (60)
    -Firelance Starhost (110) (Required)
    Eternal Starhost (130)
    Total: 2500/2500 Points
    Leaders: 6/8 Battlelines: 6 (4+) Behemoths: 4/5 Artillery: 0/5
    Edit: I'm not sure what that IMG bit is, or why I can't get rid of it.
  2. Jeddaven
    Jeddaven New Member
    Also, I wanted to note that I'm using Dracothion's Tail to deal with Skyre shooting -- in particular, so I can summon stuff into their lines so I don't spend several turns closing and eating mortal wounds.
  3. Saminator
    Saminator Member
    Looking cool, but I think you need three saurus guard units for the eternal starhost (i mifht be wrong).
    Joshmunga and Seraphage like this.
  4. Jeddaven
    Jeddaven New Member
    Ah, yep, you're correct. I'll probably just split the second guard unit, then.
  5. Joshmunga
    Joshmunga Member
    What would be the role of the EotG in this list??
  6. Aginor
    Aginor Fifth Spawning
    I guess with the Slann you have a decent chance to get some of the better results out of the EotG, so you might be able to use it both for healing your multi-wound units (like the Carnos or the Slann) and for causing mortal wounds to your enemy.
    Joshmunga likes this.
