Hi gus, I'm slowly building my army up and am still a bit of a noob. So far I own the following: 48 x Skinks 12 x Warriors 20 x Knights 1 x Saurus Oldblood on Carnosaur 1 x Bastiladon 1 x Skink Starpriest 1 x Engine of the Gods I'm looking to purchase some more models to create the attached 2200 point army. My questions: What do you think I can drop to get this to 2000 points if needed? What artefacts do you think I should choose for my leaders? Which Leader should be my general? Any other criticism is welcome! I normally play against Ironjawz and Sylvaneth.
Ok, let's see.... Ok, first of all: Kitbash yourself two Skinks so you have 50. You can use parts from the Stegadon and Ripper kits for that. About the list: Who is your general? I assume the ScarVet on Cold one to make the Saurus Knights more effective. You could probably drop one of the bataillons. The Firelance isn't _bad_ per se, and the idea of using it together with a Shadowstrike for a Hammer & Anvil tactic is tempting, but it probably won't be super effective here. The other thing is: everything will outrun the arriors, and even if they do get into combat they won't do much. IMO not worth it. So variant #1: Merge the Knights into 2x10 and drop the Firelance. Also drop the Warriors. Variant #2: Drop the Engine of the Gods. Without a Slann to improve its result it isn't worth it IMO.
