I was thinking about 2000p list from models that I have and finished with something like that Lord Kroak 540 Thunderquake Starhost 1100 2 bastiladons troglodon 3 kroxigors 30 saurus warriors 300 razordon 60 2000p in total. What you think about that list? my other models are Scar veteran on carnosaur scar veteran on cold one 16 saurus knights 10 temple guards 5 chameleon skinks 3 handlers
I'not so sure about it. The Thunderquake is perfect but Kroak not so much. He costs a quarter of the army, can only cast a single cosmic deliverance (due to the faq on the rule of one ) and cannot use the Troglodon as vassal (one of troglodon 's advantages ). Personally, i would employ Kroak as normal Slann ( to have also the support of the constellation ), freeing 280 pts for that delicious carnosaur as general, buffing it with Order's command trait and artefact. Also, i suppose that those 30 warriors will be divided into 3 units of 10 each, to cover the battleline requirements.
thanks for reply yeah I've notice yesterday that Kroak is extremely overcosted, especially with three rules of one not allowing him to cast celestial deliverance three times My new idea is Thunderquake starhost 1020 bastiladon bastiladon troglodon razordon+handlers slan starmaster 260 and now 2 options Firelance starhost with scar veteran on carnosaur will fill points up to 1960 or Firelance starhost with scar veteran on cold one will allow me to field 20 saurus warriors
Carno all the way. Handlers for a single razordon are wasted points. Can't you field 2 razordons, proxying one model?
If you're going for seraphon allegiance then your kbightz are battleline and you should take the Carno. If you want the irder binuses you will likely have to drop the firelance starhost altogether and field maybe a sunclaw.
Hmm having this 40 spare points I can actually proxy engine of the gods instead of troglodon... But having slan I can make better use of troglodon... Which one will be better troglodon or eotg?
not having any units to summon roll of 14-17 will be wasted I guess? unless I can use use slannpower to add 4th dice and pick smallest numbers?
I dont rly get the 14-17... I can put ANY of the Seraphon units in the game? Without any point costs for summoning etc?
No for this ability in matched play you must set aside the points. In open play you could theoretically summon lord kroak into the battle. But for matched play any abilty that can summon units needs to have the points available.
I'll play eotg+Slann+Starseer in a thunderquake. I think i use most of the rerolls for the engine to get the heal or extra round
