AoS 2000pts Thunderquake
Discussion in 'Seraphon Army Lists' started by Awbbie, Mar 18, 2018.
  1. Awbbie
    Awbbie New Member
    Hello! So I am still a relatively new Seraphon player and I am currently planning out how I'm going to take my army to 2000. I am building from a Start collecting and my models from the Malign Portents painting competition. So this is what I am planning so far:
    Slann - Arcane Might, Incandescent Rectrices - 260
    Astrolith bearer - 160
    Skink Starpriest - 80
    Scar-vet on cold one - 100
    Saurus Cavalry - x10, Lances - 200
    Saurus Warrirors - x10, Spear - 100
    Salamanders - x3 - 120
    Troglodon - 180
    Stegadon - Sunfire Throwers - 240
    Stegadon - Sunfire Throwers -240
    Skink handlers - 40
    Thunderquake - 170
    Any suggestions?
  2. LordRibbit
    LordRibbit Well-Known Member
    A bastiladon or two will give you some great options in the future, they really make an army very durable! May I ask what the priest is for? with the thunderquake you can get a lot of the same buffs! Maybe put a bow on one of the stegadons?
  3. Awbbie
    Awbbie New Member
    Well, the skink Starpriest is there to fill in some points and provide some more spells/dispells.
  4. LordRibbit
    Apologies, i misread it for a priest! That makes much more sense!
  5. dinoSTARZ
    dinoSTARZ Active Member
    If the troglodon dies, do you still get all the benefits of the batallion? If the units have to be within so many inches of the troglodon to get the re-rolls I worry that theyll kill my trog and then those 200 points for thunderquake will drop off
  6. Seraphage
    Seraphage Well-Known Member
    Unfortunately you don't. And yes you are right, it is the biggest downside of the batallion. Most of the times you'll be able to protect it with placement and spells. Tzeentch will be a horrible match up with Skyfires and their MW spam but then again, Tzeentch always are a huge problem :p
    Buldi likes this.
  7. Slanntastic
    Slanntastic Member
    I believe you still get the healing benefits of the battalion just not the re-rolls.
  8. dinoSTARZ
    Man thunderquake is so expensive at 170! The only batallion I've ever tried is firelance and it wasn't useful in the game I tried it in. It seems that you need to keep your thunderquake men close together (8") which is a pretty big disadvantage against the stormcast's shots for instance, where they do D3 mortal wounds at each unit from a point (hitting your razors, handlers, slann, trog, bastilidon/stegadon). Those who have played the thunderquake, how does it work for you?
  9. Aginor
    It worked well for me each time.
    The healing even takes some of the danger out of the damage a Celestant Prime or a Dracoth can cause.
  10. Slanntastic
    Slanntastic Member
    I like it a lot and I have been pretty successful. I run 2 bastiladons, an EotG, and one sallie. I try to keep the basti's with the EotG but usually have to send one off to deal with something or another. Like Aginor said the healing is great and when they are close together the basti's are so tough. I had one soak up like 80 attacks from skeletons and take 2 wounds, which I then healed back 1 on my next hero phase.
    Seraphage and Buldi like this.
  11. dinoSTARZ
    Do you run both bastilidons with solar engines? I want to pick up another and make it an ark of sotek. I don't feel like magnetizing, but I guess I could just do "counts as" if I need to switch them up.
  12. Aginor
    You don't even have to magnetize them. You can just put them there and fix them with a tiny amount of poster putty on the bottom.
    I usually run the Solar Engine because of its range, but against a melee army I can imagine the Ark of Sotek version could be fun, too.
    I still think that especially in the Thunderquake with its range limitation the Solar Engine is easier to use. If you play a teleporting list or So, so you can choose the point you attack at, then the Ark can shine because you can maximize its damage potential.
    Seraphage and dinoSTARZ like this.
  13. Slanntastic
    Slanntastic Member
    I don't have them magnetized or even glued. I just have them sitting on the racks. If I am playing a tournament I use solar engines, they are more versatile and consistent. That being said the ark is a ton of fun. I have a goofy list that has a basti with the ark, a stegadon, and a slann with the double teleport. I teleport the steg and basti into a good position and then use the alpha skink ability on the steg to push the basti up and try to get the ark into as many possible targets as possible.
    ChubbSkink, Aginor and Buldi like this.
