  2. Have you ever felt that your miniature cabinet is missing something? Don't fret, we have you covered.
    Take a look at the awesome bust's offered by 3DArtDigital, they will look awesome on display.
    Click here for more information.
KoW AltiBash IV [4 games - 2x 1800pts, 2x 2200pts)
Discussion in 'Battle Reports' started by BAE, Jun 23, 2017.
  1. BAE
    BAE Well-Known Member
    I'm off to another tournament next weekend, AltiBash IV, and this one has a bit of a twist when it comes to army composition!
    "Army Composition
    You must submit 2 force lists (1800 and 2200 points)
    You must retain a minimum of 1600 points of units within your 2200 point list. You cannot remove artefacts or options from a retained unit but you may add to them. Each list must abide by the normal list composition rules, including CoK modifications;
    • Within your main force, you cannot select the same unit entry of type War Engine, Hero or Monster more than two times at 1800 points, or three times at 2200 points.
    • You may take up to 450 points of allies at 1800 points, and may add an additional 100 points of allies in your 2200 point list.
    • If you include allies, you cannot select the same allied unit entry of type War Engine, Hero (all types) or Monster more than once.
    • Magic artefacts cannot be given to any allied units you take."
    It turns out it is remarkably difficult to get two strategically coherent lists, one of which fits inside the other. However, after much mulling over the conundrum I came up with the following:
    1800pts:
    Hordes
    Salamander Primes w/ Brew of Haste
    Fire Elementals
    Fire Elementals
    Ancients on Rhinosaurs w/ Maccwar's
    Regiments
    Kaisenor Lancers w/ Healing Brew
    Troops
    Salamander Unblooded
    Monsters
    Lekelidon
    Lekelidon
    Heros
    Herald w/ Sparkstone
    Mage-Priest w/ Surge & Inspiring Talisman
    Battle-Captain w/ Wings of Honeymaze
    2200pts:
    Hordes
    Fire Elementals w/ Wine of Elvenkind (*hat tip @Itepixcauh*!)
    Fire Elementals
    Regiments
    Troops
    Ghekkotah Warriors
    Ghekkotah Warriors
    Monsters
    Greater Fire Elemental
    Lekelidon
    Lekelidon
    Heros
    Mage-Priest w/ Surge & Mounted
    I'm fairly sure that these will be the lists that I take, but I would definitely appreciate any ideas if others suggest them! I've had a I have until Wednesday to submit my lists. In terms of scenarios, the new 'in thing' seems to be to announce the scenarios immediately before each game, so I can't provide any information there.
    This is up in your neck of the woods again @Crowsfoot - any chance you might join us?
    Itepixcauh likes this.
  2. Itepixcauh
    That means youu have tried the nimble elementals trick. They are mazing at getting into flanks!
    Looks like a good pair of lists
    BAE likes this.
  3. BAE
    I haven't tried it yet - this tournament will be the first!
  4. Itepixcauh
    Just tell me how they did!
    BAE likes this.
  5. BAE
    So, the debrief - I had an absolute shocker and got the wooden spoon! I also learned just how important practice games are, particularly when you are including a unit as expensive and powerful (and therefore strategy-changing) as the Ancients on Rhinos for the first time.
    While horrific dice luck at pretty much every pivotal moment did play a part (honestly, I was spitting feathers at times!), I was fighting an uphill battle every game as my deployment was extremely weak. I'm not really sure what happened, but I think the issue I found was that my strategy thus far has essentially revolved around a Primes Horde as central pivot, with FEs and double-surge on the flank, and Lancers on far end of the same flank. The Lancers would clear out the opponent's unit nearest the board edge, allowing the FEs to move forwards and wrap around their flank, slowly chewing their way through the opponent's army sideways while the Primes and other units distracted and held firm in the centre. Having not played with them before, I was putting my Rhinos alongside my lancers on the far flank with the idea that they could get around the side and start causing havoc. While bad dice luck stopped the Rhinos from being as effective as they should have been, they did cause some serious damage to units that they hit. The problem with deployment of the Rhinos was that extra units on the flank pushed the FEs further into the centre, which then wrecked their ability to get any flank changes. Without flank charges, FEs are quite weak (only hit on 4+!), meaning my centre kept folding before I could bring the Rhinos to bear. I need to get some practice games in to work out what to do, but I'm thinking that rather than deploying Rhinos on a flank I might try putting them further to the centre than the FEs. Instead of trying to get brutal flank charges with the Rhinos I'll use them to hit the front of units, and as such, something like Blood of the Old King might be more useful to deal maximum damage. By doing this, the FEs will then be able to go back to their traditional roll wrapping around the opponent's flank, which surge tricks make them incredible for.
  6. BAE
    By the way, due to AoRs still being on painting bases they sit really far forwards to spent most of the games facing backwards!
    Game 1 (Loss)
    IMG_20170701_100225.jpg IMG_20170701_100242.jpg IMG_20170701_102547.jpg IMG_20170701_104344.jpg IMG_20170701_110100.jpg IMG_20170701_111749.jpg
  7. BAE
    Game 2 (Draw)
    IMG_20170701_115742.jpg IMG_20170701_120422.jpg IMG_20170701_121024.jpg IMG_20170701_122421.jpg IMG_20170701_123340.jpg IMG_20170701_123743.jpg IMG_20170701_124852.jpg IMG_20170701_130051.jpg IMG_20170701_130616.jpg IMG_20170701_131434.jpg
  8. BAE
    Unfortunately no pictures of Game 3, so Game 4 (Loss):
    IMG_20170701_162519.jpg IMG_20170701_163958.jpg IMG_20170701_165950.jpg IMG_20170701_171524.jpg IMG_20170701_172715.jpg IMG_20170701_173914.jpg IMG_20170701_174146.jpg IMG_20170701_174808.jpg IMG_20170701_175008.jpg IMG_20170701_175503.jpg
    Crowsfoot and Itepixcauh like this.
  9. Itepixcauh
    Amazing report, Thank You!
    Taking last place is actually great. It's an experience and it's funny. If you are going to get low on the table better be the last and go home with a price.
    Joking aside, the Ancients are amazing but I agree with you not easy to use at all. I'm still working on them myself. A lot of games they just die from a multicharge before doing something significant, such a juicy target for the enemy, but as with the Fire Elementals and the Skylord I will find the way.
    BAE likes this.
  10. Negator
    Negator Member
    Glad to see you keep trying to make salamanders work
