AoS Bastiladon's MW save
Discussion in 'Rules Help' started by Xasto, Nov 15, 2017.
  1. Xasto
    Xasto Well-Known Member
    Hey y'all,
    Was wondering if the reroll failed save rolls also apply to the Basti's MW save of 4+?
    Let's say that the bastiladon has been the target of the Skink Priest's Celestial Rite (If I do remember correctly the name), does the reroll to failed saves only apply to his normal 3+ wound save or does that extend to his MW save as well?
    Dr Kaos and Crowsfoot like this.
  2. Crowsfoot
    The rule says "save rolls" so MW should be covered as it is still a "save roll" for that unit.
  3. Xasto
    That is what I thought and what was accepted in my group of friends, as this is what seems to make the most sense too!
    Makes you really think about how sturdy a Basti + Skink Priest combo can be!
  4. Solaris
    Solaris Member
    No, it doesn't apply! A save roll is specifically a roll that is governed by the "Save" characteristic on a units warscroll. Impervious Defense is an ability, and so is not affected by Celestial Rites.
    Seraphage likes this.
  5. Aginor
    I agree. It is a roll that happens to have a defensive purpose, but it is not a save.
    Edit: but then if you got away with it....;):angelic:
  6. Killer Angel
    I would add that also in the text, the ability to ignore MW is not described as a save...
  7. Xasto
    Ah well I guess it was too good to be true!
  8. Robertxtrem
    Robertxtrem Active Member
    If it said "You may make a 4+ save roll against mortal wounds" then it would allow rerolls but it doesn't use the word save in the ability.
  9. Soul Zenmuron
    Soul Zenmuron Member
    You can still save them with insights from Kroak or Starseer
  10. Canas
    It depends on if it's called a save roll on the warscroll or not. however since it says "when suffering a mortal wound on a roll of 4+ it's ignored" it does not mention it is a save-roll. It's an ability completly seperate from saves.
  11. Seraphage
    Seraphage Well-Known Member
    Yep it is as @Canas says but Curse of Fate + Kroak dice can still affect it
