AoS Battleshock and Cold-Blooded
Discussion in 'Rules Help' started by Tilorn91, Mar 19, 2020.
  1. Tilorn91
    Tilorn91 Active Member
    Guys, the cold-blooded rule states clearly on page 55 that we ignore modifiers to bravery both positive and negative, while on page 5 of the core rulebook it says that slain models are a modifier to the bravery roll.
    I know it is probably intended not to work in a broken way together, but it seems pretty clear that we can't have fleeing models almost ever?
  2. Grotpunter
    Grotpunter Well-Known Member
    You are immune to banners, spells etc. that modifies your Bravery. A battleshock test is something different.
    Your Bravery is 5 - This cant be changed as per above.
    You lost 5 dudes.
    You roll a 1 = You add the amount of dead guys to the dice roll = 6. 1 guy will run from battleshock.
  3. Tilorn91
    Third paragraph of the Battleshock Phase rules directly say it is a modifier though,
    If the modified battleshock roll is
    greater than the unit’s modified
    Bravery characteristic, the
    battleshock test has been failed.
    Edit: I know I'm probably wrong, but I'd like to know how and why more precisely.
  4. Grotpunter
    I dont see how that is relevant to a battleshock test. You have 2 numbers and compare them. One cant be modified, the other can still be.
  5. Shocksem
    Shocksem Active Member
    To battle shock rolls not to bravery. It also means you miss out on the bravery buff for having more than 10 models.
  6. Tilorn91
    Ah, I see. Thanks for explaining!
  7. ILKAIN
    ILKAIN Well-Known Member
    yeah cold blooded is actually bad for hordes.
    Erta Wanderer likes this.
  8. ILKAIN
    it should just be "you don't take battle shock tests" our lore literally is all about standing to the last man and never retreating.
    Canas and ASSASSIN_NR_1 like this.
  9. Canas
    Aside from the fluff it's also a fairly meaningless rule. With the exception of some very specific builds it's very rare to have a lot of bravery modifiers anyway for most armies. Which means that against most armies it stops the effect of 1 whole banner or something. Which is just super underwhelming. Hell, mirror matches are probably where you'd get the most use out of it ironically given that we have a fair amount of modifiers...
