Tutorial Caleb's Seraphon Strategy Videos
Discussion in 'Seraphon Tactics' started by Caleb ex nihilo, May 19, 2020.
  1. Caleb ex nihilo
    Caleb ex nihilo Well-Known Member
  2. Bush4321
    Bush4321 New Member
    Cool videos. Well thought out and some great tips. Keep up the good work.
    Lizerd and Caleb ex nihilo like this.
  3. Killer Angel
    Great!
    I've stickied the tread and changed it's tag to "tutorial"
  4. Caleb ex nihilo
    These aren't your normal Skinks! They have some tricks up their sleeve. While they may not fit in every list, I think they still have a role!
  5. Lizerd
    Lizerd Well-Known Member
    Carnosaurs amen.
  6. Caleb ex nihilo
    Slann vs Kroak!
    Should be an easy answer... ;)
  7. Nart
    Nart Well-Known Member
    Shouldn't be a question.:D
  8. valentine009
    valentine009 Member
    You should do one on the Endless Spells. Good targets, how best to position, whether it's worth taking the bound version, etc.
    Caleb ex nihilo and Lizerd like this.
  9. Caleb ex nihilo
    Good idea!
  10. Caleb ex nihilo
    Terradons vs Ripperdactyls
  11. Krissey
    Krissey Active Member
    My only problem with the Starseer is he has a 5'' movespeed, it just doesn't seem viable to use him for the 3D6 charge. Teleporting him with Lords of Space and Time to be wholly within 12'' feels kind of like suiciding him into the middle of the board. Who is going to be around to screen him or in anyway protect him? He's so slow compared to these. Doesn't it seem a bit impractical on the table to bank on that?
  12. valentine009
    valentine009 Member
    Well unlike a lot of other models you pretty much lose nothing if you run with him every turn (which you won't be doing with what you want to charge with).
    As a result you can almost think of his movement as 5' + 3.5' (average d6 roll), or even 11' if you have the CP to auto run 6'.
  13. Caleb ex nihilo
    Yep, def a risky move. I was just trying to figure out how to make the most of our gutted Shadowstrike battalion.
    Krissey likes this.
  14. Krissey
    That’s understandable! I think with Fangs of Sotek and Chronomatic Cogs you can get a lot out of a first turn strike. Keeping them on the board seems like the best move. Keep their Chieftan near them for the CA and ability to like put other generic command abilities on them.
    the first list I’m going to try is running 12 (2 blocks of 6), Kroxigors and 60 skinks with supporting heroes :p I love the models
    Caleb ex nihilo likes this.
  15. ILKAIN
    ILKAIN Well-Known Member
    I want to make a correction to your threat range table at 11:43 for the Terradons. You get the base move and run correct at 26", but then you give the charge range as +4 to +13... you forget the 3rd die on the high side. their actual threat range is 30"- 45" with the buffs you are using.
  16. Caleb ex nihilo
    I <3 Stegadons! Haha, the Steggy Chief is a beast with the right buffs!!
    - Coalesced (+1 to Jaw attacks)
    - Thunderquake (+1 to melee attacks)
    - Constellation (+1 to melee attacks)
    - TL Cmd Trait Prime Warbeast (+1 Mount attacks)
    - Skink Chief Cmd Pt (+1 to melee attacks)
    And he is putting out 22 damage vs a 4+ save! Nice! Not bad for just 1 cmd pt spent!
    Get a bit more nuts...
    - Reroll 1s to hit (StarPriest spell or Cmd Pt)
    - Cmd Pt from Skink Priest for +1 to hit
    And he is putting out 32 damage vs a 4+ save!
  17. Kilvakar
    Kilvakar Well-Known Member
    Just used essentially that build to defeat the Skaven! My Skink Chief on Stegadon blasted a horde of Clanrats from 40 to 19 with his flamethrowers and a MW on the charge. Then he was able to take out Lord Skreech the Verminking in the combat phase, and this was after taking 4 wounds from a Warp Lightning Cannon on the way there. He went down to another Clanrat horde after that, but the Skaven were crippled and my other two Stegadons, Lord Kroak, and a full-sized Salamander Hunting Pack were able to secure the win.
  18. Caleb ex nihilo
    Beautiful!!!
  19. Caleb ex nihilo
    Summoning got changed for Seraphon in the new Battletome! It is alot more random now, but NOT dead! Summoning is more of an added benefit of Starborne instead of a strategy to plan an army around.
  20. Grotpunter
    Grotpunter Well-Known Member
    Played a couple of games by now with Slann + Kroak + Astrolith + Trog and I have never summoned anything but 10 Skinks or 1 Salamander. I was gonna make a points to CCP ratio analysis myself since I was curious of the most efficient options, so thanks alot for this! Both options just seem to have the biggest outcome of all of them (obviously different roles of screen vs damage output) - It also makes sense seeing they are some of the better pointed options in regards to points to CCP ratio. I think we can all agree Salamanders are probably a bit too good at 80 pts, so the ratio of 8 is a little misleading imo.
