AoS Carnosaur: oldblood vs Scar Vet?
Discussion in 'Seraphon Discussion' started by Kroq-bro, Mar 15, 2020.
  1. Kroq-bro
    Kroq-bro New Member
    So, with the new tome out, what is the verdict on the Carnosaur.
    I cant for the life of me figure out why the oldblood is so muh more expensive than the Scar vet.
    The scar vet seems like the obvious choice, but maybe there is something im not seeing?
    So what is your take on this whole debacle?
    LizardWizard, Lizerd and Dragvindel like this.
  2. Flo
    Flo Well-Known Member
    Why not both?
    But to answer your question, OB got a missile attack, so in do dmg in 2 Phases, also his CA is awesome (go Saurus!)
  3. Dragvindel
    Dragvindel Well-Known Member
    Id say it depends on the list, most would want the oldblood for the abilities and range damage. But if you have a battalion that works better with the SV like the Firelance Templehost, then go with it.
    Or if you have 210 points to spend on a behemoth I'd take the SV lol
  4. Putzfrau
    With the +1 attack SA, the flat 3 damage of the old bloods spear really shines.
    It really depends tho. Scar ver is prolly better just on sheer efficiency
    PabloTho, LizardWizard and Lizerd like this.
  5. Flo
    SA?
  6. Asamu
    Asamu Well-Known Member
    Scar vet is 40 points cheaper and basically just as good in melee, so I'd say scar vet, but you might go with both in some lists, like a firelance koatl's claw list.
    3 damage spear with 3 attacks at rend -1 vs a 6 attack 2 damage spear with no rend (on the charge) is generally going to be similar damage from the rider, but the latter is better with weapon artefacts.
    The command abilities math the same on average, but the scar vet command ability is less consistent.
  7. Lizerd
    Lizerd Well-Known Member
    I would start with an oldblood on Carnosaur, for 40 more points your getting a down right terrifying melee weapon. Using blade of realities or some other rend -3 artifact makes it even more ridiculous. It also makes a pretty good lynchpin for any saurus army, as it’s pretty tough and scary to get into the melee with.
    if you get more carnosaurs, then assemble additional ones as scar veterans, as multiple Oldbloods become redundant
    PabloTho, LizardWizard and Dragvindel like this.
  8. Putzfrau
    Sacred asterism
    LizardWizard, Flo and Lizerd like this.
  9. LizardWizard
    Oldblood's command ability and spear are why he cost 40 points more. ScV has more potential for damage depending on Artefacts though.
    Lizerd and Nart like this.
  10. Nart
    Nart Well-Known Member
    IMO, they are balanced pretty good against each other and best work in tandem and more a support heroes for saurus-based armies. But Oldblood is a bit better, it you want to include him as a horde-killer in the skink or beast-centered army. His bonus is more consistant and he still can face other monters, while Scar-Vet simly may miss all jaws attacks (4+ to-hit sucks). Scar-vets CA are nice, of course, but you may just roll too few 6's, if you use it on himself.
    So, Oldblood is a bit better but costs more. But scarvet is still viable, if you desperately need spare 40 points.
    Lizerd likes this.
  11. Boshea
    Boshea Active Member
    Both get pretty big combat boosts when they are on a Carno, so if you got the points its worth it for either. If taking multiple Scar-Vets are probably better to take additional of just for being 40 points cheaper. Scar-Vet is also probably the most sad off his Carno getting only the Warpick, but the Oldblood kind of just a worse Sunblood when on foot.
    Lizerd likes this.
  12. Tiderox
    Tiderox Active Member
    Looking at the warscroll builder the Oldblood spear now does D3? I thought it was 3.Ninja nerf instantly? I hope not and it’s just an error...
    Lizerd likes this.
  13. Nart
    Looks like it's still not updated.
    Lizerd, Erta Wanderer and Teheloqtec like this.
  14. Teheloqtec
    Teheloqtec Active Member
    It's also D3 on the AOS app's warscroll, but the pdf you can download from GW still states 3 o_O
    Lizerd likes this.
  15. Nart
    The codex entry will be the final arguement until the FAQ. It is the same as pdf, I believe.
    Lizerd and Teheloqtec like this.
  16. Kroq-bro
    Kroq-bro New Member
    what?? if is 3 damage, then that changes things.
    PabloTho and Lizerd like this.
  17. Titchy_Stryder
    Titchy_Stryder Active Member
    It’s 3 damage in the codex. That only changes for me if there’s an errata.
    ILKAIN, Lizerd, Flo and 1 other person like this.
  18. Pallys
    Pallys New Member
    What weapon with the scar vet is best?
    Lizerd likes this.
  19. Lizerd
    Warspear, with the right buffs and a sword of judgement it can deal d6 mortal wounds on a 4+ to a hero or monster
    Imrahil, Nart and Pallys like this.
  20. ILKAIN
    ILKAIN Well-Known Member
    sword of judgement is not "unmodified 6's"? fricken sweet! I had forgotten that
    Lizerd likes this.
