AoS Carnosaur tactics
Discussion in 'Seraphon Tactics' started by Scurvydog, May 29, 2019.
  1. Scurvydog
    Scurvydog Active Member
    I have been trying to get a clear sense of which carnosaur version to bring to which job, and also very importantly how to equip them with artifacts.
    There are some obvious differences and and minor once and I will try to list out the pros and cons for each version, assuming NO artifacts in the equations. All damage is assumed to be on a target with a standard 4+ save model, without rerolls or aftersaves.
    Old Blood on Carnosaur:
    Pros:
    -Slightly more offensive with an average of 6.00 damage. With rerolls (from astrolith or sunblood) this goes to 8.56. Also 0,78 damage from shooting on average.
    - Bite attack is only 4+ to hit but 3 damage. Against monsters with no hit modifiers and hitting with both claws this goes to 2+ for full benefit.
    - Command ability never useless, even for himself. Against monsters +2 attacks on claws is a good idea. Can stack this with more command points for burst damage.
    Cons:
    - No build in surviveability with a 4+ save.
    - costs 20 more points than scar vet.
    - Not part of a single battalion but only a "super battalion".
    Scar Vet on Carnosaur:
    Pros:
    - Has the most surviveability with ignoring rend value of -1. Common rend value, so can add up quite a bit.
    - 20 pts cheaper than old blood.
    - Has a few interesting offensive artifact options due to weapon profiles with 6 attacks for the rider.
    Cons:
    - Carnosaur bite is only d3 damage, but hits on 3+ though. If the "pinned down" rule triggers on a monster with no hit modifiers, the +2 to hit will only actually give +1. Many heroes on monster like -1 hit artifacts however.
    - Not an option in Fangs of Sotek as an old blood is required.
    - Command ability best on massed saurus, which is most often used in a fangs of sotek list... see above.
    - "only" 5.35 average damage and 7.39 with rerolls, so scales worse than the old blood, especially if command abilities are used.
    Overall:
    If not building for a specific battalion, I feel it comes down to basically offense vs defense and possibly even points. If part of a Gristlegore heavy meta, then the offense might swing in favor of the scar vet with blade of judgement, but that is somewhat niche perhaps.
    Assuming a take all comers approach, I tend to favor the old blood just a slight bit more, but with a defensive artefact, such as miasmic blade or doppelganger cloak. Ethereal amulet could also be an option, especially if backed up by a skink priest to reroll saves. He is still very vulnerable however and none of these artefacts help with mortal wounds.
    Especially in a smaller game, if you can stack a few CP, even the old blood alone with just 2 CP can get 9 bite attacks, with rerolls from astrolith or sunblood, this brings him into 1 shot territory on average against most monsters (not an etheral VloZD though).
    Request:
    I'd like to hear the experiences and opinions of you guys, did one type of Carnosaur save the day or fail miserably? Could that have been different if the other variant had been used? How do you like to equip them, including interesting combos with other heroes?
  2. ASSASSIN_NR_1
    Interesting. I haven't tried the Oldblood yet, the scar vet however have don nothing but die to my opponents Idoneth deepkin.
    One thing the Oldblood has over the scar vet is as you have said his command ability, which can make him a lot more killy. If you can take the same artefact more than once, which I have found nothing against, well then in bigger games the oldblood could statistically get infinite attacks. You do need two battalions to pull it off, since you want three Aetherquartz brooches. Then each time you use a command point you roll 3 dice and get a command point for each 5+, which statistically should happen each time with three dice.
    Imrahil and LizardWizard like this.
  3. Dan32234234234324
    Dan32234234234324 Well-Known Member
    I am fairly sure you cannot take duplicate artifacts.
    Ecozh, ILKAIN, Imrahil and 1 other person like this.
  4. ASSASSIN_NR_1
    That might very well be true, I just haven't been able to find any clarification on whether it is allowed or not.
  5. LizardWizard
    This is correct, all artifacts are considered unique.
    Imrahil and Dan32234234234324 like this.
  6. LizardWizard
    Ironically I just had someone ask me why I prefer the ScV Carno over the Oldblood. I am lazy, so I am just gonna quote myself.
    Aginor, Imrahil, Lizerd and 1 other person like this.
  7. Lizerd
    Lizerd Well-Known Member
    Well well well, carnosaurs. my favorite.
    So in general with carnosaurs you really want to maximize their effectiveness so I will go in-depth into both of them. Please note I run a saurus heavy sunclaw and fangs of sotek.
    So what do these guys specialize in? Well this should be obvious, they are monster hunters. And they are damn good ones at that. To what extent? Well really good ones. From my personal experience I have had my Oldblood on carnosaur beat the life out of a zombie dragon, live, and survive the rest of the battle with minimal damage. So to maximize this there are a few things to consider.
    First off is buffs, usually all you need is an artifact and some other minor buff and it should do fine. The stuff I will usually use is a light of the heavens and maybe the serpent staff. Both from the skink starpriest. Other stuff like reroll hits and wounds are effective but not mandatory. Onto artifacts. There are really two options, offensive and defensive artifacts. While defensive stuff is not bad there are other, and often more effective ways of protecting a carnosaur. For the scar veteran with spear, sword of judgment is excellent. For the Oldblood and other scar veterans, usually a rend 3 artifact will do. This is generally beneficial and allows for thick armor to be a non factor.
    Onto protection. As stated earlier artifacts are decent but there are better ways to do this. One option that is definitely effective is a screen of skinks, or if your weird like me, saurus knights. This generally works out fairly well and is a solid strategy. Another good option here is defensive buffs, reroll ing saves and -1 to be hit is always nice.
    Ensuring victory is the final and most important step. Pick a target, get a screen, and follow these directions. Carnosaurs, if they get the drop on something, are near unstoppable. And here you MUST ensure you strike first. Here is where oldbloods really shine. Two extra claw attacks ensure all bites go off, and with some luck the opponent will be killed or crippled. If this is a hero or monster, even if they are not outright killed, they will be so injured they cannot put up much of a fight.
    Imrahil and ASSASSIN_NR_1 like this.
  8. ASSASSIN_NR_1
    Where is this written?
  9. LizardWizard
    It is the 5th rule of one for matched play.
  10. Wilhelm Stürmer
    Lizerd, Imrahil and LizardWizard like this.
  11. LizardWizard
    Another great defensive artifact to consider for Carnosaurs is the Doppelganger's Cloak. If used correctly you can avoid retaliation attacks for one round of combat. It also allows you to engage with our other glass hammer units and avoid the difficult choice of rather to swing with our Carno or glasshammer first.
    Nart and Lizerd like this.
  12. Nart
    Nart Well-Known Member
    Olblood on Carno with Doppelganger cloak is probably our only way (besides 16 razordons, of course) to deal with "always strikes first" and "forces to attack last" monsters, which became quite numerous in current meta.
  13. Killer Angel
    Yeah, the 2 "defensive" settings for our carno, boil down to:
    1) Doppleganger Cloak; mitigate the "Always strike first", but you'd better hope to kill your target
    2) stack -1 to hit from artefact and -1 to hit from Summon Starlight. -2 is a pretty good insurance.
  14. Blitzkriyg
    Blitzkriyg Well-Known Member
    Old blood is always the better choice of you want damage output . With his shooting and command ability on his Jaws, he can pretty much go through any unit
    Imrahil, LizardWizard and Lizerd like this.
  15. Lizerd
    Short answer: yes. The Oldblood is probably one of our most formidable units.
  16. Blitzkriyg
    I really hope they get buffed to terrorgeist general levels
  17. Killer Angel
    So much this...
  18. Nart
    I will be fine with just very strong.:D
  19. Womboski
    Womboski Well-Known Member
    Wait the oldblood on carnasour's command ability can effect his mounts weapons? I thought only his spear was an eligible option for the extra attacks.
  20. Lizerd
    Well currently due to the outdated warscrolls, none of our models have the “mount” rule meaning that the carnosaur’s claws and jaws are legitimate options to augment with command points.
    Womboski and LizardWizard like this.
