Tutorial Casting parts using blue stuff
Discussion in 'Tutorials' started by Crowsfoot, Oct 12, 2017.
  1. Crowsfoot
    Just browsing you tube last night and found this, looks pretty easy for casting parts
  2. Aginor
    Hah! I ordered some of that stuff (called Oyumaru) just a few days ago and will try it soon.
  3. Crowsfoot
    Yeah I'm going to do the same.
    Ritual likes this.
  4. Bracnos
    Bracnos Well-Known Member
    Been doing this for some time it works great
  5. Slannta's Little Helper
    Slannta's Little Helper Well-Known Member
    I've ordered it also recently waiting for it to arrive :)
    Ritual likes this.
  6. Fhanados
    Fhanados Well-Known Member
    Anyone know how this stuff stacks up to QuickMold? Seems to be similar stuff. I got QuickMold a few years back for a birthday present but never got around to using it due to my living situation being somewhat cramped at the time.
    Ritual likes this.
  7. Aginor
    I heard it is pretty much the same thing as Oyumaru or Blue Stuff. There are even more.
    Quoting another forum post somewhere on the Internet:
    "There are other craft thermoplastics on the market. Some brand names are Polly Plastics, PolyDoh, PolyMorph, ThermoMorph, Friendly Plastic, and Moldamer"
    Ritual likes this.
  8. Lord Agragax of Lunaxoatl
    I've certainly heard of PolyMorph. Just out of interest, what sorts of materials are best for making the moulds you need to cast miniature parts of your own? It certainly appeals to me to be able to make my own minis instead of buying more!
    Ritual likes this.
  9. Crowsfoot
    Blue stuff is what makes the moulds it's called Oyumaru @Aginor
    Ritual likes this.
  10. Aginor
    My package of Oyumaru arrived yesterday.
    It is just a tiny little amount but it will suffice for some tests. Might be able to try it out in the next few days.
  11. Crowsfoot
    Please put pics in your blog
    Ritual likes this.
  12. Eyeless1
    Eyeless1 Member
    So, ignoring the ethical problems, would it be possible to create a mold for the FW gameday Slann? And how much blue stuff would I need?
    I have one, and I need another.....
    Ritual likes this.
  13. Lord Agragax of Lunaxoatl
    Cheers @Crowsfoot. If Oyumaru is for the moulds then what could be used for casting the minis themselves?
    Ritual likes this.
  14. Crowsfoot
    I think 2 part epoxy putty etc
    Ritual likes this.
  15. Lord Agragax of Lunaxoatl
    You mean like GW's green stuff?
  16. Eyeless1
    Eyeless1 Member
  17. Slannta's Little Helper
    I've used my blue stuff already it works amazingly well I used green stuff in the mould pressed it down and left it to cure inside before removing it some hours later
  18. Aginor
    I did some tests tonight.
    Interesting stuff. Pics soon on my blog.
    As material for filling the molds: if it is for terrain you could use clay, air drying clay, and every resin that doesn't become hot when it cures.
    If you want to make models: some epoxy putty like green stuff or milliput is probably the best.
  19. Crowsfoot
    Milliput superfine might work, stuff like that, I suspect greenstuff would work.
    I need to get some blue stuff and try it soon.
    Ritual likes this.
  20. Bracnos
    Green stuff works for one part mold you have to really put it in there to make sure you get all the small details. From what I found with practical use when you use blue stuff or the other brands of it's the same material. If you use it to make two part mold you need a really soft and malleable epoxy mix. I would suggest millput or another brand since those are really soft and mix it with green stuff. And be really careful when you're making a two part mold. If you add too much pressure when squeezing both houses together. It can and in many cases it dose (im my experience with it) push the material out the sides of the mold and leave you with cavities or missing details. Causing you to waste valuable material and you need to make sure you're really pressed the blue stuff on the parts you want to duplicate or agaun youll be left with missing details...i have been using it alot and ill make a thing about on my blog soon
