AoS Cogs question
Discussion in 'Seraphon Tactics' started by Slikus Vaw, Mar 7, 2020.
  1. Slikus Vaw
    Slikus Vaw Active Member
    So was wondering something about the cogs. It ses you can have a wizard activate the cogs in your hero phase but it does specify when do say if you make it do the extra cast then your next hero phase come to you use your spell along with the extra spell from cogs would you be able to switch it to fast to get both benefits from the cogs?
  2. Erta Wanderer
    yes you chose which to use each turn
    A_Reptile_Dysfunction likes this.
  3. A_Reptile_Dysfunction
    A_Reptile_Dysfunction Well-Known Member
    I think he means something else.
    So you activate it turn 1 to slow down time and use the extra spell. Then it comes back to your second turn and it’s still set to slow so use the extra spell. However you’ve not “activated” the cogs for your turn two.
    So I think what he’s asking is can you use the extra spell turn two and then decide to activate it for extra move/charge in the same turn.
    In that scenario the answer would be no, as cogs states the effect only lasts until your next hero phase.
  4. Erta Wanderer
    no you cant use both it gets activated at the start of your hero phase (exept when it is first summoned) before you cast spells
