AoS Curse of fates D3 interaction
Discussion in 'Rules Help' started by ILKAIN, May 11, 2018.
  1. ILKAIN
    ILKAIN Well-Known Member
    If I have a curse of fates on a wizard unit that successfully casts mystic bolt (or any other D3 mortal wounds spell) and I roll a 2 on a D3 (a real D3, I have them lol) do I bump to 3 or is there a rule that says I have to use a D6 and count 1/2 for 1, 3/4 for 2 and 5/6 for 3? the wording on the spell says "a single dice roll"
  2. Crowsfoot
    If you have a D3 that is the die to use if you don’t have a D3 use a D6 the rule says roll a D3 so your opponent cannot argue if you own and roll a D3, I have them as well
    ILKAIN likes this.
  3. Aginor
    I don't have something from GW about it, but IMO:
    The range of a D3 is 1-3 so curse of fates would change a 2 to a 3 obviously.
    The D6/2 rounded up is just a bandaid because most people don't have a D3. Which of the d6 sides created the 2 is irrelevant. The roll was a 2 so you can change it to a 3.
    Ecozh, Canas and ILKAIN like this.
  4. ILKAIN
    Thank you gentlemen I was simply concerned that I may have overlooked a rule that specifically made us use actual D6’s
  5. Flo
    Flo Well-Known Member
    Bad News for you.
    In the AoS Rules it is stated clearly that all dice rolls are made with a D6 and then converted to the D3, you will always have to roll 6 sided dices. They stated this to stop people from fooling around with things wherever they haven't statet D6 (roll a dice - great i take a D100)
    So with the Curse of Fate you increase the roll on a D6 and after that it is halved and round up
    1 on a D6 stays a 1 on D3
    2 on a D6 goes up to 3 and therefore is a 2 on D3
      File size:
      47.2 KB
      9
  6. Aginor
    Good catch, so yeah, technically the "real D3" is not allowed in Age of Sigmar.
    But following GW's logic the point is still increased after the roll, so after halving and rounding the total of the D6 since that is part of the roll. Note how they use the word "total" and not "result" here. That's because the result of the roll is what the virtual D3 shows.
    So if he rolled a 3 on the D6 (which becomes a 2 on the D3) and then uses the spell to increase the result of the roll by one, it becomes a 3.
    He does not go back to the D6 total before halving, applying the bonus to create a 4 which then after halving and rounding also becomes a 2.
    Curse of Fate will work on a D3, I am absolutely sure that's what is intended.
  7. ILKAIN
    well that's pretty clear cut.
    *grumble grumble*
    lol jk, this is why I asked, obviously I want to win, but not at the cost of my integrity. I will have to correct the matter when next I play that individual.
    *EDIT*
    posted this as Aginor was responding lol... that does make sense. (and of course I like the answer better) damn we need some official clarifications for a lot of things in this game lol.
  8. Crowsfoot
    Hmmm I can't see a poblem rolling a D3 for a D3 roll just like you don't measure from the model we all use base to base.
  9. Flo
    Yeah but measuring Base to Base is a House Rule, of course if your opponent(s) agrees to your house rules everything is fine ;) But for the Basic Rules it's a D6 :)
  10. Aginor
    Yeah, although the reason they included it is mostly that they don't have to say D6 every time they say dice.
    I don't see a problem using a real D3 either, as the results are absolutely the same.
  11. Flo
    Not when using Curse of Fates :D
  12. Crowsfoot
    I get that but a D3 among friends would be fine.
    Roll a D6
    1,2 is a 1
    3,4 is a 2
    5,6 is a 3
    Or am I missing something
  13. ILKAIN
    just re-read curse wording and the rules image Flo posted, the interactions between the two absolutely have you roll, half the number to get the result, then adjust the result of the roll by 1 per the ability. so the 2 damage becomes 3. Thanks every one!
  14. Aginor
    Yes they are. I explained it above.
    There is no D6 result when the warscroll says D3. Just a D6 total that gets halved and rounded to get the D3 result.
    And the result is what is changed by the spell.
  15. Flo
    Yes but if you increase the roll by 1 you have
    Roll a D6
    1+1 is a 1
    2+1 is a 2
    3+1 is a 2
    4+1 is a 3
    5+1 is a 3
    6+1 is a 3
    EDIT: ah okay so CoF is applied after the roll of the D6/2 then it's the same :D
  16. Aginor
    Yes. Check the wording. Curse of Fates changes the result. What the d6 shows is not the result.
    Flo and Crowsfoot like this.
  17. Crowsfoot
    Right so going off that you are better rolling a D6 as you have 3 (50%) chance of getting 3 damage opposed to one chance on a D3 (33%) and only a 16% chance of getting 1 damage on a D6 but on a D3 your minimum damage would be 2 (1+1)
    Rolling a 3 on a D3 is pointless as you can't add the +1
    Makes sense now ;)
