AoS Curse of Fates Question
Discussion in 'Rules Help' started by Joshmunga, Nov 24, 2017.
  1. Joshmunga
    Joshmunga Member
    If you cast CoF on a unit, could it be used to increase the roll for the Lord of Space and Time ability? Letting you change a pesky 1 to a 2 so you are able to teleport them?
  2. Aginor
    IMO the wording clearly says yes.
    Reasoning:
    The LoSaT ability says that you "roll a dice for the unit" and the Curse of Fates spell says you can "increase or decrease the result of a single dice roll for that unit" each phase.
    Edit: I also think that's the very reason why the Starseer is one of the only two Seraphon units that got a point increase. That synergy is strong.
    Joshmunga likes this.
  3. Killer Angel
    Yes, for the reasons said by @Aginor .
    Even if I believe the starseer costs more for the re-roll ability. Especially given that you can have a Slann with CoF basically for free...
  4. Seraphage
    Seraphage Well-Known Member
    Yes it does for sure. I 've been working with this long time. Never tried double tp due to rolling 1s all the time so I went for the Vast Intellect.
    *My record to this day is out o 21 rolls : 6 2-4, 1 5, 1 6 and 13 1s'.. fun times :p
  5. Joshmunga
    Joshmunga Member
    some how, it seems like 1's always beat the statistics!!! DX
    Seraphage likes this.
  6. GingerGiant
    GingerGiant Member
    It can be used for almost everything, except, perhaps the Ark of Sotek, which specifically references the numbers on the dice rolled. It's really good to apply to a d3 roll, since it affects the result. A d3 is effectively a die that reads "1, 1, 2, 2, 3, 3". The troglodon can benefit a lot from Curse of Fates, as it significantly increases the likelihood that it deals a wound.
