AoS Double shadowstrike
Discussion in 'Seraphon Army Lists' started by MackiMac, Mar 25, 2019.
  1. MackiMac
    MackiMac Well-Known Member
    Do you think this list could work?
    Allegiance: Seraphon - Mortal Realm: Ulgu
    LEADERS
    Skink Priest (80)
    - General
    - Command Trait : Master of Star Rituals
    - Cloak of Feathers
    - Artefact : Incandescent Rectrices
    Skink Starpriest (80)
    - Artefact : Prism of Amyntok
    Saurus Scar-Veteran on Carnosaur (240)
    - War Spear
    - Artefact : Sword of Judgement
    UNITS
    6 x Ripperdactyl Riders (280)
    12 x Terradon Riders (480)
    - Starstrike Javelins
    40 x Skinks (240)
    - Boltspitters & Moonstone Clubs
    10 x Skinks (60)
    10 x Skinks (60)
    5 x Chameleon Skinks (120)
    BATTALIONS
    Shadowstrike Starhost (180)
    TOTAL: 2000/2000
    EXTRA COMMAND POINTS: 2
    WOUNDS: 139
    Aginor likes this.
  2. Wilhelm Stürmer
    Can I ask what your rational is for running 40x Skinks without shields and not using Bolas on the Terradons?
  3. MackiMac
    Thats just the way my skinks are modelled, they where not able to have both the blowpipe and shield when I made them.
    Bolas are probably better, but would it not be though to get all 12 of them in range?
  4. MackiMac
    12 Terradons with javelins will average on 8 wounds and 12 with bolas on 10,5 wounds before saves. The longer range of the javelins is worth a couple of wounds I think and bolas looks like they will break very easily.
  5. Wilhelm Stürmer
    But would you not get more damage from the Bola drop and then swooping dive attacks?
  6. MackiMac
    Yes if you can place all twelve Terradons within 5” of the enemy, I just not sure on how often you will be able to do that
  7. Wilhelm Stürmer
    Fair point. I could see that being difficult on a unit of less than 30 models.
  8. Killer Angel
    Before reading the list, i was thinking "oh, another try with double rippers that is not going to work".
    Instead, we have 6 rippers and 12 (!) terradons.
    At least this idea is interesting... you can descend with everything since turn 1, the rippers will do their usual works, while the terradons are going to drop (on average) 6d3 mortal wounds, plus the javelins and the melee on an already weakened unit.
    Not bad, but the problem is what you could face at 2000 pts: you use flyers and skinks (which are probably going to die in droves when your opponent recovers from your Alpha strike), and at that point you have only the carnosaur.
    It could work, depending on the battleplan and the kind of objectives you must take.
    Aginor likes this.
  9. Wilhelm Stürmer
    @Killer Angel makes great points. The lack of any Slann means you're banking on massive Alpha Strike damage, which while Shadowstrike can be really good, it's not top tier. Many armies will recover and likely obliterate the flyer units.
    Aginor and Killer Angel like this.
  10. Aginor
    I kinda like this list.
    Yes, it is a one trick pony. If you don't win in turn one you are probably dead.
    Also: Two bataillons is a lot of tax, even in 2K.
    Another problem could be placement. I have played lists with six Terradons and on a table with a good amount of terrain placing them might be hard already. 12 is a LOT (that's the reason I agree with the javelins btw, you probably won't get into range with all the bolas anyway).
    But yeah, if it works in turn one you can do quite some damage.
  11. Killer Angel
    it also matters who you face.
    against FEC, for example, it would be a suicide, as you need to erase the units (and 12 terradons are not going to blast 9 flayers), and the same would be against LoN ("you killed my 40 skeletons... well, here they are again")
  12. Aginor
    Against the undead you would have to use the akpha strike against the heroes, it could work. When you can kill a Mortarch or a Ghoul King on Terrorgheist in the first turn that's worth something.
  13. Killer Angel
    not so easy to do.
    a list a friend of mine played at 1750 was along these lines:
    abhorrant
    abhorrant
    infernal courtier
    abhorrant on terrorgh
    9 flayers
    10 ghouls
    10 ghouls
    10 ghouls
    (royal family)
    you can wipe (MAYBE, it also depends on the placement of those screening ghouls) the terrorgheist or the flayers, not both. And at that point there's not so much you can do
    Aginor likes this.
  14. Aginor
    In the end it boils down to them being stronger. If the modern armies choose a good list and/or have a good player we are screwed.
  15. Killer Angel
    yeah, pretty much...
