Posted this in a reply to another thread but thought I'd stick it here too: I think I've come up with my list for GT final, not expecting to get massively high up the rankings but should be fun (barring massive changes in GH2): Starseer (160) Star priest (100) Skink Priest (100) Priestley Trappings, Celestial Rites 2 x EotG's (480) 2 x Phoenix Stone 1 x Bastildon Laser beam (300) 1 x Stegadon Flamethrowers (260) General, Legendary Fighter 40 x Skinks Boltspitters and clubs (320) 10 x Skinks Boltspltters and clubs (80) 10 x Skinks Javelins and Shields (80) Heavenswatch Starhost (100) Total: 1980 Normally I'd go for a shadowstrike but this is a one drop army meaning I probably go first. Buffing my dinos with celestial rites giving armour re-rolls plus the healing 1 wound per turn (2 for EotGs) makes it very durable. Plus with the star seer spell and re-roll probably get 2 D6 mortal wounds first turn at least, stegadon giving one an extra D6 move in the hero phase will put it in range of a hero or two. Plan would be to use the Engines to snipe heros and concentrate the rest of the firing on one unit at a time, re-rolls of 1's to hit and wound will do a lot of damage. Thoughts?
Seeing as you have 7 units, I assume you're dropping one of the skink units outside the starhost. I would probably drop the second engine for a slann for the control over the engine output, Your odds of summoning nothing instead of firing a couple of turns are pretty decent. And you have two drops as the Heavenswatch can have 3-6 units and you have 7 here. Though I do like thetwo engine idea, I think it just works better to have 4 dice and choose the three to make it more effective.
You're right! For some reason i though it was 3-9! I do see your point about the Slann but i thought i'd give myself a bit more of a challenge, plus i think GH2 may change the summoning rules a little at least. Am hoping with the starseer i will have a little more control over the engines, the slann is just overpiced for what they do atm for me.
Ohhh I thought that it couldn't either use the Command Trait ! That's a wonderful information, thanks !
