Hello my scaly friends! I am absolutely stymied by the assembly of my Eternity Warden and I'm hoping someone out there can help. Specifically, the weapon and arm do not seem to line up no matter what I do. If the left arm (molded to the staff) is flush against the body, the bottom of the mace goes below the feet, and the right arm doesn't line up with the right hand. Near as I can tell, all my pieces are straight and clear of flash. Alternatively, is there a good temporary adhesive I could use to hold one piece in place while I fiddle with the rest? Blue tacky putty doesn't really cut it.
it's resin so there is a good chance that your going to have to melt it to fit it properly or just fill in the gaps with green stuff
I had the some problem with mine. I ended up using a different arm entirely. I would recommend cutting the right arm at the elbow and use green stuff to make it straighter. That should give you plenty of wiggle room to fit the hand into place
Thanks for the advice! I was able to cut partway through the elbow and straighten the arm into place. Or at least close enough that I can fill in the gaps with green stuff.
While I certainly wouldn't mind seeing our resin kits swapped over to plastic, I'm quite happy to have this one on the table.
