How to glue Miniatures to pink foam
Discussion in 'Painting and Converting' started by Lord-Marcus, Sep 16, 2017.
  1. Lord-Marcus
    I'm going to build some columns out of pink foam, how is the best way to glue terradon to pink foam?
  2. Crowsfoot
    Magnets I reckon
  3. Lord-Marcus
    Uggh
  4. n810
    Plastic or metal terradons ?
    also what part is being glued.
    ps. if it's the plastic ones, I have an idea...
    take a bit of longish sprue cut out of your scraps,
    and impale it into your foam block where you want it connected,
    (you may need to drill a hole first) I would hot glue this bit to the foam.
    them use regular plastic glue to connect your plastic parts.
    tom ndege likes this.
  5. Lord-Marcus
    They are the metal terradon. I got a bunch of em in a lot.
  6. n810
    Hmmm..... similar idea....
    Except use a nail instead of sprue,
    and use some epoxy wield instead of plastic glue...
    Also you may have issues with your model being a bit top heavy.
    so plan accordingly.
