Is it possible to build a Stegadon in a way that allows it to be turned into an EotG?
Discussion in 'Painting and Converting' started by Stormscales, Oct 19, 2017.
  1. Stormscales
    Stormscales Active Member
    Before I commit to buying the Stegadon box, I'm curious if there's any way at all to build it in such a way that you can switch between a Stegadon and an Engine of the Gods by removing/adding magnetized parts, such as the sunstreak bow and the ring of the Engine.
    I'm aware it would not be a perfect switch: e.g, you still have to choose a front plate for the howdah, and there may be some issues with the positioning of the Skinks. Luckily my usual opponents are not the nitpicky type: all that matters is that there be no ambiguity about what the monster is being fielded as.
    (And I don't need a step-by-step description of how to do it, I can probably figure it out on my own. I mostly want a yes or a no.)
    Warden and Captaniser like this.
  2. n810
    Warden, tom ndege and Stormscales like this.
  3. tom ndege
    I think I once saw one model that was upgraded that way... blue table painting iirc... also I think one can always make one of the options as a kind of conversion (something that looks similar but not exactly like the original) in order to make swapping from one of the other a bit easier...
  4. tom ndege
  5. n810
    Oh my second steg Can be converted to
    great bow, blowpipes or skink chief/Tenehuian.
    Ps. although I didn't do it,
    I recommend magnetizing the banners to prevent them from snapping off.
    as most of mine are broken now. :meh:
  6. Aginor
    I also made mine convertible between all versions. Over sixty magnets. Overdid it a bit... you can find it in my blog thread.
    tom ndege likes this.
  7. tom ndege
    Number three...
    I knew I haven't seen only one...
    would have been strange if there wasn't at least one on this board...
  8. pendrake
