Tutorial Jungle Basing for LIZARDSSS
Discussion in 'Tutorials' started by jacintomateus, Apr 18, 2016.
  1. jacintomateus
    jacintomateus Active Member
    As some of you requested I made this small tutorial on my basing scheme for my JUNGLE lizards!
    Hope you like it and find it useful.
    Its really a very basic scheme but I find it to work great for my Lizardmen.
    Step Zero:
    Starting with black painted bases.
    These ones I mixed a bit of sand and static grass to the Black paint itself to give some more texture.
    But as I will cover the most of the base perhaps this is not really really needed, I just like the effect it creates.
    Step One:
    Paint the Base in a brown colour.
    I use a mix of 2 colours to give a more natural "muddy" look.
    Just paint and blend the colours directly on the base and brush.
    Don't need to be very clean as we will clean the bases later.
    How they look when dry.
  2. jacintomateus
    Step Two:
    Apply the Tufts.
    This is where the line between my professional life and hobby life starts to get fuzzy, because I work with the company that makes these excellent tufts. But I like very much to use our product and believe it to be very user friendly and provide good results with little effort.
    So... a bit of shameless promotion on GamersGrass Tufts.
    I start with the bigger tufts (12mm tall) and I use 2 colours to give some realistic variation on the colours.
    Then I add the flowers and shrubs.
    (on these larger tufts and the shrubs I like to add a little PVA glue to the base of the tuft, just to make it adhere better.)
    Then I pretty much cover almost the rest of the base with the small tufts (MOSS)
    (And these I do not add any glue to them.)
  3. jacintomateus
    Step Three:
    Clean the edges of the bases.
    I paint the edges in black to clean the mess I did when painting in brown.
    And how they look when joining the ones I did previously!
    They come from the JUNGLE!
    Hope you like them and that in someway you find this usefull for your basing.
  4. n810
    Very Nice. :D
  5. tom ndege
    Nice one! Thanks for that!
  6. Bowser
    Fantastic! Looks brilliant!
    Awesome!!!
  8. Crowsfoot
    Can't beat a good looking base ;)
  9. Jorgik
    Jorgik Well-Known Member
    Real cool mossy bases :)
  10. Xenoch-Tochal
    Xenoch-Tochal New Member
    Those bases are gorgeous! What miniatures are on them, may I ask?
    jacintomateus likes this.
  11. Jorgik
    I think they are the old edition saurus
  12. tom ndege
    Yes! Some old fifth edition saurus with modern weapons and standard... I also still have about 30 from back in those days. But mine are not painted up so nicely! ;)
  13. jacintomateus
    Yes, they are the old fifth edition saurus.
    But with toothpicks to make them with spears hahaha!
    Jorgik likes this.
  14. tom ndege
    Oh. But looks quite modern! ;) the original 5th edition saurus spears look quite clumsy compared to toothpicks!
  15. jacintomateus
    As promised the rock basing tutorial!
    PART ONE
    First the rocks!
    I use raw cork for the best effect...
    I like to puncture the large pieces with a screw driver and a hammer and then brake them appart.
    Then choose the good pieces that I want:
    And test fit the model! (yes! the model is a lizard, at least this part of the model is...)
    Then sand the base of my pieces to make a nicer flatter bottom part.
    (also helps with gluing the pieces to the plastic base)
    Super glue all the way!
    I use a full bottle (3gr) of super glue on this base.
    (I buy them in my Chinese store near my place for .25€ each...)
    It glues the pieces onto the base and also impregnates the cork making it very hard once the glue dries.
    (this glue is very very thin, so all texture is maintained)
  16. jacintomateus
    Part TWO, let the mess begin!
    Disclaimer! This part can be a little messy if you do it in a small space...
    Mix sand, PVA glue and Acrylic paste.
    I find that if I mix just the PVA and sand the final texture will not be very sharp, as the glue when dries, smooths a little and in does not give the desired effect... So I also add the Acrylic paste to the mix!
    MESSSS!!!!
    More MESSS!
    And look at the target base hoping for the best...
    (the superglue has not dried at this stage... but who cares!!!)
    Add the mixed paste!
    .... now the whole thing takes some hours before I dry, so the tutorial will continue after it is all dried...
  17. Jorgik
    Looking forward to seeing how it continues! For now it looks very promising!
  18. jacintomateus
    The base dried over night...
    Continuing...
    PART THREE, painting...
    Base is primed, and then suffers highlights using the airbrush to make the rocks stand out.
    Then a general brown wash is applied to blend all together and start to create the natural dirt/mud effect:
    A second brown wash is applied on the dirt parts leaving the rocks clean:
    Then I start to work on the small river:
    ...and realized that I do not have the water effects to continue...
    So the Tutorial continues next part.... (need to go and buy the water thingy)
  19. Jorgik
    It looks awesome!!
  20. jacintomateus
    And adding some water effects (Vallejo Still Water)
    and some Vegetation (GamersGrass Tufts and Shrubs) this is the final effect...
    Hope you like it...
