8th Ed. Khaine Slann and the Stegadon
Discussion in 'Lizardmen & Saurian Ancients Tactics' started by Bainbow, May 15, 2015.
  1. Bainbow
    Bainbow Well-Known Member
    So here's a question. In the Khaine magic rules, you can recast any spell that has a casting value of 14+ or less so long as you don't fail to cast it. This means that spell such as the Purple Sun of Xereus, Chain Lightning, and the very powerful Final Transmutation can only be cast once per turn. However if you were to use the Engine of the Gods to lower the casting value of such spells, would that meant that they could be cast multiple times?
  2. Qupakoco
    Worded as such, yes.
  3. Skinquisitor
    Skinquisitor Member
    Its a yes. Does it fulfill the criteria? Yeah. Any words about unmodified casting value? No :)
    Scalenex likes this.
    There is nothing I can find that would make it illegal. It sounds like it is a go!
  5. Scolenex
    Scolenex Well-Known Member
    Twas mentioned before. Check out this Tactica for other Khaine magic goodies.
  6. Bainbow
    Ah, thanks for that, bamboo man. I'll look at it.
