Help Kroq Gar on Grimlock conversion help
Discussion in 'Painting and Converting' started by Irish Lizarman, Sep 22, 2018.
  1. Irish Lizarman
    Irish Lizarman Active Member
    Hey guys i have an old metal Kroq gar on Grimlock and im looking to upgrade him a bit with the new plastic old blood head and arms from the star collecting box so id like to get peoples ideas for any help, and also how in the frig can i attach him and take him back off again for storage? any and all help is welcome and i will post pics when he is done
  2. Irish Lizarman
    work so far lol just held together with gluetack to see how it looks
  3. pendrake
    Can you zoom in on the interface area? o_O What does the bare back of the beastie look like?
    Irish Lizarman likes this.
  4. Irish Lizarman
  5. Irish Lizarman
  6. pendrake
    It does help. Right then:
    How do you feel about gluing two small steel (must be ferrous metal) washers underneath the saddle?
    What about carefully drilling two corresponding, magnet shaped, cylindrical holes in the back of the beast? Embed magnets** in shallow holes.
    Call that ^ idea One.
    ________________
    It looks like there is a tiny amount of clearance under some portions of the saddle. Try ordering some **neodymium magnets that are 1mm thick by 3mm diameter or maybe 4mm. Find out if there is room under there for magnet to magnet connection.
    SuperGlue two under the saddle; two to the back of the critter.
    Call that ^ idea Two.
    Irish Lizarman and Aginor like this.
  7. Irish Lizarman
    i will try to do the washer trick but i don't understand how to attach them like on the inside of the saddle yeah or flat?
  8. pendrake
    Test by dry fitting. From what I can see in the pix it looks like there’s two spots on each side where a tiny washer might fit.
    Flat against the inside of the saddle, one each side is what I would go for. They’d end up angled compared to the table surface.
  9. Irish Lizarman
    Ive tried a bit the magnets i have arent strong enough so ill have a look tomorrow in town and might see what i can get
  10. Irish Lizarman
    TA! DA!!! ITS ALIVE! ITS ALIVE!!!
  11. Aginor
    Aginor Fifth Spawning
    That looks pretty rad!
  12. Irish Lizarman
    cheers dude im pretty proud
    Aginor likes this.
  13. Deed525
    Deed525 Well-Known Member
    Very good :)
