AoS Looking to start Seraphon for a league
Discussion in 'Seraphon Army Lists' started by Thor0298, Mar 7, 2016.
  1. Thor0298
    Thor0298 Member
    30 wound cap
    7/30 can be 1 hero
    8/30 monster/warmachine
    (if it has both keywords it counts as both keywords and double wounds in the cap)
    Slann (7 wounds)
    10 Saurus guard(10)
    3 terradon (9)
    1 salamander (3)
    My league is heavy with undead players and nurgle. My other army is fyreslayers so could mix the two. I was thinking for 80 could mix but the seraphon have many options by themselves. The fyreslayers have shown to be lacking in quite a few areas so I thought I'd try seraphon since I have a bunch. Games are six rounds
  2. Crowsfoot
    What is the wound cap for Kroak 7?
  3. Thor0298
    Thor0298 Member
    No idea checking with the guy at the store. With how he set things up im guessing probably 10. But I guess I'll see later what he says
  4. Thor0298
    Thor0298 Member
    I know most of what I'm playing is festus with blight kings,black Knights, grave guard, necromancers. Especially with most of the times of war being played the fyreslayers squad I have is getting demolished. Just looking for something a bit more competitive
  5. Bainbow
    Bainbow Well-Known Member
    What models do you have available? Tell me everything you have.
    Also don't mix armies outside of themed armies, you trade away synergy and synergy is king in AoS.
    Bracnos and Bowser like this.
  6. Thor0298
    Thor0298 Member
    I know I need a seraphon hero yet
    Two carnosaur kit - one not built
    16 Saurus Knights
    12 Saurus Warriors
    2 stegadon kits -not built
    3 terradons
    1 bastiladon
    1 salamander
    Don't know if you wanted to know fyreslayers too. Guessing not but here's what I have there
    15 auric hearthguard
    1 magmadroth
    1 grim wrath berserker
    20 vulkite berserker
  7. Bainbow
    Hm... if it's only 30 Wounds, you're going to be rather limited on how much synergy you can bring... for the most part, I reckon tactical synergy should be the best way forward as opposed to ability synergies. Based on what you've got, I'd recommend this list.
    Bastiladon w/ Solar Engine
    Slann Starmaster
    12 Saurus Warriors
    The Bastiladon goes without saying because it's basically our best monster. Have Mystic Shield on it as much as possible and it'll never die, plus its Solar Engine can hit really hard if the Dice Gods smile on you, and if you're up against any daemons then they're toast. The Starmaster is ideal for his Constellation abilities, the Great Drake being the best choice here because it'll make hitting much easier for you. The Salamander is good for destroying armour and causing high burst damage, use it for shooting into combat and hit-and-run tactics. And split the Knights into two units, for such a small game their normal weakness of As for the Warriors, they should be there to counter any infantry to stop you from being overwhelmed by numbers, however in such a small game they have a disadvantage due to having no horde bonus so make sure they're neve in combat alone, always bring the Basi to their fights.
  8. Thor0298
    Thor0298 Member
    What if you bumped to 50 wounds. There's a league there to
  9. Thor0298
    Thor0298 Member
    For division one I could take the bastiladon or the hero not both they limited to one or the other. I'm guessing the bastiladon
    Misread that I can take both
  10. Thor0298
    Thor0298 Member
    Isn't that list only 20 wounds?
  11. Bowser
    8 for the bastiladon
    7 for slann
    12 for saurus
    3 for salamander
    That's 30
    Bainbow likes this.
  12. Bainbow
    Hm... if you bumped up to 50, could you get any more Hero wounds? A Starseer, for example?
  13. Thor0298
    Thor0298 Member
    Yeah get twelve total so that should be ok
  14. Thor0298
    Thor0298 Member
    What would be good for the rest of the 50 wounds adding in the Starseer?
  15. Bainbow
    Well how many monster Wounds do you have to play with now?
  16. Thor0298
    Thor0298 Member
  17. Thor0298
    Thor0298 Member
    Here's the four divisions. The wounds double count if they are a hero monster and take up the wounds in both categories. Like the 12 wound magmadroth takes up the hero and wound cap in d2 and he's counting that as 24 wounds out of the total
  18. Bainbow
    Well then that's not enough to get another monster, so just stick to the Basi.
    At least 33% of your Wounds should be spent on infantry, so that's 16 Wounds. Seeing as how you only have 12 Warriors, you'll have to switch them for 8 Knights to serve as your infantry. Which is fine. So that gives you 12 Wounds left to spend... hm... honestly based on the models you've got, it may be smart to just spend those remaining wounds on more Knights to bulk up your core seeing as how you can't spend them all on a Stegadon. That'd give you what, 14 Knights which you could split into two units to pull of alternating charge/retreats, assuming that they have Lances.
  19. Thor0298
    Thor0298 Member
    Is it worth getting another to summon one
  20. Bainbow
    You could, but never make the summoning attempt the focus of your casting because it's long odds. Only try to summon the beastie if you have a spare spell to burn.
