AoS Lords of Space and Time
Discussion in 'Rules Help' started by Crowsfoot, Jul 4, 2018.
Tags:
  1. Crowsfoot
    I watched a Batrap last night and he rolled a D6 for LoSaT and after a pop up said "Roll a D3 now" but I can't find any rule errata to confirm this.
    So is LoSaT a D3 roll now?
    Cheers
    Crow
  2. Aginor
    That's a negative, sir!
    It is still a D6, but 1-2, 3-4,and 5-6 are the results.
    I hear you asking: "Why @Aginor, isn't that the same?"
    Now... it isn't the same. Not completely. You will see the difference if you start applying modifiers like Curse of Fates to it.
    Ecozh, Nart, professor_lust and 3 others like this.
  3. MinhoAbernathy
    MinhoAbernathy Member
    I mean...in the GHB 2018
    a 1 or 2 is can't move
    a 3 or 4 is teleport but can't move
    a 5 or 6 is teleport and move
    So it IS basically a D3 roll
  4. Aginor
    No it isn't.
    It says D6:
    Furnus and Crowsfoot like this.
  5. Aginor
    Example making clear what the difference is:
    Old rule: You roll a 1. You use Curse of Fates to make that a 2. All is good.
    New rule: You roll a 1. You use Curse of Fates to make that a 2. All is NOT good.
    If it was a d3 (which it isn't): You roll a 1or2. You use Curse of Fates to make that a 3-4 (on a d3). All is good.
    Ecozh, Teheloqtec, Freddy25 and 2 others like this.
  6. MinhoAbernathy
    Not that you can treat it as one...
  7. MinhoAbernathy
    I understand
  8. Crowsfoot
    I get that it just threw me when he said D3 as I had just put the book down with D6 in it. :rolleyes:
  9. Killer Angel
    if you compare the new table to the old one, the positive thing is that with Curse of Fate now only the 1 is negative, while 4-5-6 are very good results.
    we "pay" with a 1/6 chance to be blocked, the 50% chance of being able to teleport, move and charge. Which is huge for oldblood on carno, stegadon, dread saurian...
    Aginor and Crowsfoot like this.
  10. Aginor
    Indeed, the "extreme" results basically became more likely.
  11. Furnus
    Furnus Member
    Can LoSaT be used twice on the same unit in the same turn in case the first teleport fails?
  12. Aginor
    I would say yes, I don't know any rule that would restrict that.
    Furnus likes this.
  13. Audvin
    Audvin Active Member
    I have an additional question and thought it unnecessarily to make a new thread.
    On a roll of 3 or 4 the unit can not move. Does this also mean no charge? Usually it would state both move and charge if that was the case. Or can you only charge on a 5-6?
    I guessing it can charge either way since charges happen in a different phase?
  14. Aginor
    It can charge and it can pile in.
    All abilities that prevent normal moves and charge moves say so explicitly.
    Audvin likes this.
  15. Aginor
    Edit
    Sorry, phone hiccup
