AoS Newbie 2k list
Discussion in 'Seraphon Army Lists' started by Valdis16, Nov 6, 2019.
  1. Valdis16
    Valdis16 New Member
    Hello guys,
    I am a new player and this is my first army list, as I don't have any experience I put what I thought would be good, or at least fun to play, anyway. I am not looking for the strongest most meta list but still I don't want to take a bad path and end up with an unplayable army.
    Here is my list
    Allegiance: Seraphon
    LEADERS
    Slann Starmaster (260) -
    General - Command Trait : Great Rememberer
    Saurus Scar-Veteran on Carnosaur (240)
    Warblade Skink Starpriest (80)
    Saurus Eternity Warden (140)
    Saurus Astrolith Bearer (160)
    UNITS
    3 x Kroxigor (150)
    3 x Ripperdactyl Riders (140)
    3 x Razordons (120)
    3 x Skink Handlers (40)
    5 x Saurus Guard (80)
    10 x Skinks (70) - Meteoric Javelins & Star Bucklers
    BATTALIONS
    Eternal Starhost (150)
    ENDLESS SPELLS / TERRAIN / COMMAND POINTS
    Chronomantic Cogs (80)
    TOTAL: 1940/2000
    EXTRA COMMAND POINTS: 1
    WOUNDS: 104
    And don't really know what to think about the Saurus Scar-Veteran on Carnosaur. I also feel like I have to much small units.
    Also which artifacts would you advice ? Also are wardrums really usefull ?
  2. LizardWizard
    Welcoime to Lustria!
    I like your list. Eternal Starhost is a fun army.
    With your floating 60mpp you should consider taking a Balewind Vortex for your Slann to cast. The Skink handlers will also be a bit superfluous if you are near your Astrolith when you shoot with your Razordons.
    Valdis16 likes this.
  3. Slikus Vaw
    Slikus Vaw Active Member
    kroxigors are my fav unit. they work are more effective 6+ models(same with rippers) but you have to watch how you place your moon hammers. i have had mine tear thru hordes and win games in my thunderquake.
    a good artifacts would be the spellmirror on your Warden if you know you're going against some spells to protect your guard. another one is incandecent rectices on your astrolith
    with the small units you do a little people usually go with the minimum number of battleline units(not the size[model count] of each unit). if you take out the skinks you have an extra 140pts for something that will do more than 1 wound per shooting phase. you will most likely summon those skinks onto the battlefield with your CCP(celestial conjuration points)
    Valdis16 and LizardWizard like this.
  4. Valdis16
    Valdis16 New Member
    Thanks for you answers,
    I listened to both of your advice and remodeled my list, what do you think ?
    LEADERS
    Artefact : Incandescent Rectrices Saurus
    UNITS
    6 x Kroxigor (300)
    3 x Razordons (120)
    BATTALIONS
    Balewind Vortex (40)
    TOTAL: 1950/2000
    WOUNDS: 93
    I have this floating 50pts, with which I am not sure what I should do.
    Should I take the extra command point, maybe add one razordon, or an other endless spell, or even cut one unit to take 2 different and optimise the number of points. What would you advise ?
    Aginor, Slikus Vaw and LizardWizard like this.
  5. LizardWizard
    I like the new list.
    Floating CP doesn't generally do much for Seraphon. I would consider taking another Razordon or finding 40 point to up one of your Saurus Guard units to 10x.
    Alternatively you could take Palisade and Shackles.
    Aginor and Slikus Vaw like this.
  6. ILKAIN
    ILKAIN Well-Known Member
    50 points is a purple sun which is well costed for its effects imo
