8th Ed. Proposed 8.1 Fixes
Discussion in 'House Rules' started by Scalenex, Jul 21, 2015.
  1. Scalenex
    The goal is to take 8th edition mostly intact, only make it more balanced. This is a "living document", feel free to make suggestions or criticisms.
    If something is too powerful or too weak I'd rather tweak the points cost then change rules left and right. It's important to give every army some candy. No army should only have things go up in price.
    Presumably if we get a general consensus on Lustria-Online we could send it to our sister websites and hear them pick it apart--I mean negotiate particulars.
    It's a lot easier to make a draft when I know the army well and it has an 8th edition handbook, like Dwarves, Empire, and Vampire Counts. I can get around to making a High Elf or Warrior of Chaos list, but I don't feel comfortable drafting any other, maybe Orcs and Goblins.
    Everyone
    Ward saves apply against all magic spells and against miscast damage. This includes Magic Resistance.
    Line template attacks that strike a character riding a monster are randomized between the rider and monster (1-4 monster, 5-6 rider).
    If a circular template differentiates between the center hole and the base template and a character riding a monster is hit by the center hole, the extra strength hit is randomized between the rider and monster (1-4 monster, 5-6 rider). The the character or rider still takes the regular template hit if they avoid the center hit.
    Taking a non-magical ranged weapon upgrade does not preclude any character from taking a non-magical hand weapon upgrade even if it says “one of the following”.
    Lizardmen
    Predatory Fighter applies to supporting attacks.
    Magic Items
    Reduce cost of Horn of Kygor by 15 points.
    Reduce the cost of the Jaguar Standard by 15 points
    Make it clear that the Sacred Stegadon Helm of Itza and Piranha Blade stack
    Reclassify the Plaque of Dominion as an Enchanted Item and reduce cost by 5 points
    Slann Mage Priests
    Add
    Focused Ferocity: Predatory Fighter units joined by a Slann may always test to restrain pursuit as if the Slann were a Skink character. This does not apply to other units within six inches of the Slann. If a Slann gains Fear or Terror, the Slann’s unit is considered to possess Fear or Terror. (Slann special characters get this too.)
    Note this will make Harrowing Scrutiny reasonable
    Raise cost of Becalming Cognition by 5 points
    Reduce Cost of Transcendent Healing by 5 points
    Reduce cost of Higher State of Consciousness by 5 points
    Saurus Oldblood
    Reduce cost of spear to 3 points.
    Reduce base cost of Carnosaur by 15 points
    Raise cost of Cold One by 10 points
    Saurus Scar Veteran
    Reduce cost of spear by 2 point
    Reduce cost of Carnosaur by 15 points
    Add
    Beast Kinship: A Skink Chief mounted on a Terradon may join a unit of Terradon riders. A Skink Chief mounted on a Ripperdactyl may join a unit of Ripperdactyl riders. Skink Chiefs on flying mounts may not join any other unit.
    Unchanged
    Saurus Warriors
    Reduce cost by 0.5 points per model
    Add “one unit of Saurus Warriors per army may take a magic standard worth up to 25 points).
    Skink Cohort
    Reduce base cost of Kroxigor by 5 points.
    Raise the minimum ratio of Skinks to Kroxigor to 10 to 1. (army list building only obviously, Skroxigor don't have to disband if the Skinks die disproportionately fast.)
    Skink Skirmishers
    Reduce the base cost by one point per model
    Raise the cost of the Javelins and Shield upgrade from free to 1 point per model
    Unchanged
    Jungle Swarms
    Reduce cost by 5 points per model
    Chameleon Skinks
    Reduce cost by 1 point per model
    Cold One Riders
    Reduce base cost by 1 point per model
    Reduce costs of Spear upgrade by 2 points per model
    May take a magic banner worth up to 50 points
    Reduce base cost by 5 points
    Terradon Riders
    Make optional swap to Fireleech bolas free
    Unchanged
    reduce base cost by 15 points
    Solar Engine costs 15 points. Ark of Sotek remains free
    Ripperdactyl
    Raise Ripperdactyl’s base Ld stat by one point
    Ancient Stegadon
    Reduce cost of Engine of the Gods upgrade by 10 points
    Salamander Hunting Pack
    Unchanged
    Razordon Hunting Pack
    Add 3 points to the base cost
    Ranged attack gains armor piercing
    Reduce cost by 40 points
    Mazdamundi
    Raise Leadership score to 10
    Add to rules
    Greatest living caster: Mazdamundi is treated as a 5th level caster
    Lord Kroak
    Add 10 points to the base cost
    Kroq-Gar
    Reduce base cost by 30 points
    Chakax
    Reduce base cost by 25 points
    Gor-rok
    Unchanged
    Tetto’eko
    Raise Ld by one point
    Raise base cost by 30 points
    Tik’tak’to
    Reduce base cost by 15 points
    Change name to something less stupid. Teploq means death from the skies and sounds close enough to the original name
    Oxyotl
    Add Hates Daemons
    Reduce base cost by 10 points (so he costs the same as 10 Chameleon Skinks)
    Empire
    Reduce cost of Griffon Banner by 10 points
    Reduce cost of Mace of Helsturm by 5 points
    Reduce cost of the White Cloak of Ulric by 5 points
    Reduce cost of Ring of Volans by 5 points
    General of the Empire
    Grand Master, Battle Wizard Lord, Arch Lector
    Unchanged
    Master Engineer
    Half the cost of all weapon upgrades (since they can’t be used while aiding a warmachine).
    Reduce cost of mechanical horse by 5 points
    Captain, Battle Wizard, Warrior Priest, Witch Hunter
    Unchanged
    Halbrediers
    Shield upgrades reduced to 0.5 points per model
    Spearmen
    Swordsmen
    Cost reduced by 0.5 per model
    Crosswbowmen
    Cost reduced by 1 point per model
    Hangunners
    Archers
    Unchanged
    Free Company Militia
    Knightly Orders
    Unchanged
    Great Swords
    Unchanged
    Demigryph Knights
    Increase cost by 7 points per model
    Reiksguard Knights
    Unchanged
    Huntsmen
    Pistoliers
    Reduce cost by 2 point per model
    Outriders
    Great Cannon
    Raise cost by 30 points per model
    Mortar
    Reduce base cost by 5 points per model
    Flagellants
    Hellblaster Volley Gun
    Unchanged
    Helstrom Rocket Battery
    Reduce cost by 15 points
    Steam Tank
    Raise cost by 25 points
    Celestial Hurricanum
    Unchanged
    Luminark
    Karl Franz, the Emperor
    Give the guy a shield. Ghal Maraz and the Reikland Runefang are both one handed weapons, and the emperor isn’t a moron.
    Kurt Helborg
    Give the guy a shield. The Solland Rundfang is a one handed weapon, and the Empire’s greatest general isn’t a moron.
    Balthasar Gelt
    Unchanged
    Volkmar the Grim
    Reduce base cost by 10 points.
    Marius Leitdorf
    Ludwig Schwarzhelm
    Give the guy a shield. The Sword of Justice is a one handed weapon, and the Emperor’s champion isn’t a moron.
    Luther Huss, Prophet of Sigmar
    Unchanged
    Markus Wulfhart, Huntsmarshal of the Empire
    Reduce base cost by 25 points--no 30 points, so someone might consider taking him
    Vampire Counts
    Vampiric Powers
    Reduce cost of Master of the Black Arts by 10 points
    Reduce cost of Curse of the Revenant by 5 points
    Reduce cost of Flying Horror by 10 points
    Reduce cost of Dark Acolyte by 5 points
    Reduce cost of Supernatural Terror by 5 points
    Reduce Cost of Master Strike by 10 points
    Vampire Lord
    Raise base cost by 10 points per model
    Reduce cost Additional Hand Weapon by 1 point
    Reduce cost of Great Weapon by 2 points
    Reduce cost of Lance by 2 points
    Reduce cost of Zombie Dragon by 20 points
    Reduce cost of Abyssal Terror by 10 points
    Master Necromancer
    Reduce Cost of Master of the Dead by 5 points, still limited to one per army
    Strigoi Ghoul King
    Unchanged
    Necromancer
    Vampire
    Wight King, Cairn Wraith, Tomb Banshee
    Unchanged
    Zombies
    Unchanged
    Skeletons
    Reduce base cost by 0.5 points per model
    Ghouls
    Add a standard bearer option for 10 points (no magic options)
    Dire Wolves
    Unchanged
    Zombies
    Unchanged (did I already list them? Oh no the zombies are spreading THE END IS NEAR!)
    Corpse Cart
    Reduce cost by 5 points per model. This carries over to characters taking Corpse Carts as a mount option
    Grave Guard
    Raise cost of upgrading to great weapons by 1 point per model
    Goal is to make people stop looking at sword and board as the crappy option
    Crypt Horrors
    Raise cost by 2 points per model
    Fell Bats
    Bat Swarms
    Reduce cost by 10 points swarm base
    Spirit Host
    Raise cost by 5 points per swarm base
    Black Knights, Hex Wraiths Vargheists
    Unchanged
    Varghulf
    Reduce points cost by 5 points
    Blood Knights
    Reduce cost of base unit by 5 points per model
    Reduce cost of the Flag of Blood Keep by 15 points
    Cairn Wraith
    Black Coach
    Terrorgheist, Mortis Engine
    Unchanged
    Dwarves
    Lord
    Lower of the cost of crossbows and handguns by 2 points each
    Lower base cost by 5 points
    Runelord
    Lower base cost by 10 points
    Lower cost for Anvil of Doom by 70 points--nah 80 points
    Daemon Slayer
    Thane, Master Engineer
    Unchanged
    Dragon Slayer
    Dwarf Warriors
    Unchanged
    Dwarf Quarrelers
    Thunderers
    Longbeards
    Unchanged
    Cannon
    This puts an un-runed Dwarf cannon on par with the points cost Empire cannons even though the Dwarves’ are slightly better (more T, WS, and BS). This is an army edge
    Gyrocopter
    Raise cost by 10 points
    Remove restriction that only half Gyrocopters may buy the Vanguard upgrade
    Bolt Thrower
    Grudge Thrower
    Hammerers, Ironbreakers, Slayers, Miners
    Unchanged
    Organ Gun
    Unchanged
    Flame Cannon
    Reduce base cost by 10 points per model
    Rangers
    Unchanged
    Irondrakes
    Unchanged
    Gyrobomber
    Thorgrim Grudgebearer
    Reduce base cost by 20 points
    Thorek Ironbrow
    Reduce base cost by 90 points
    Yes, he’s that bad in RAW
    Ungrim Ironfist
    Belegar Ironhammer
    Josef Bugman, Grim Burloksson
    Unchanged
    ASSASSIN_NR_1 and Ixt like this.
  2. Scalenex
    High Elves
    Reduce cost of Blade of Leaping Gold by 10 points
    Reduce cost of Armor of Caledor by 5 points
    Reduce cost of Shadow armor by 5 points
    Reduce cost of Gem of Sunfire by 5 points, change the first sentence to "Activate at the start of any turn, one use only." for clarity
    Raise cost of Book of Hoeth by 5 points
    Banner of the World Dragon
    Change the ward save bestowed to 3+
    I wanted to just raise the price but then I realized this item would have become BSB only completely ruining it.
    Prince
    Reduce the cost of lance by 2 points
    Reduce the cost of all other mundane weapons by 1 point
    Reduce the cost of all dragon mounts by 15 points
    Reduce cost of Tiranoc Chariot mount by 5 points
    Archmage
    Annointed of Assuryan
    Lower the cost of Flamespyre Phoenix mount option by 25 points
    Raise the cost of Frostheart Pheonix mount option by 25 points
    Lore Master of Hoeth
    Reduce the base cost by 20 points
    Noble
    Reduce cost of lance by 2 points
    Reduce cost of spear and longbow by 1 point
    Mage
    Dragon Mage of Caledor
    Lothern Sea Helm
    Add “if a second leadership test is passed, the unit may make a stand and shoot if ordinarily able but at an additional -1 to hit (to reflect the penalty for moving)” to the naval discipline rules section.
    Handmaiden of the Everqueen
    Spearmen
    Archers
    Lothern Sea Guard
    Silver Helms
    Unchanged
    Ellyrian Reavers
    Unchanged
    Lion Chariot of Chrace
    Reduce base cost by 10 points, this applies to Korhil’s mount option as well
    White Lions of Chrace
    Raise base cost by 1 point per model
    Swordmasters of Hoeth
    Unchanged
    Shadow Warriors
    Phoenix Guard
    Unchanged
    Dragon Princes of Caledor
    Lothern Skycutter
    Add note to profile. As a model with Fly, Lothern Skycutters may make a march move unless a spell or effect causes them to lose Fly. This naturally still applies when a Skycutter is chosen as a character mount.
    Tiranoc Chariot
    Reduce base cost by 5 points per model, this carries over to all characters who can take Tiranoc Chariots as a mount.
    Eagle Claw Bolt Thrower
    Move from Rare to Special
    Great Eagles
    Unchanged
    Flamespyre Phoenix
    Frostheart Pheonix
    Raise the base cost by 25 points
    Sisters of Averlorn
    Tyrion
    Unchanged
    Teclis
    Raise base cost by 5 points
    Eltharion the Grim
    Reduce cost of Stormwing by 5 points
    Alith Anar
    Add special rule “Loner: At army creation you may choose another character to be general even if Alith Anar’s leadership exceeds that of all other eligible characters. You must designate whether or not Alith Anar or a substitute is acting as general before deployment.”
    Alarielle the Radient
    Unchanged
    Korhil
    Reduce base cost by 10 points, reduce cost of lion chariot by 10 points
    Caradryan
    Raise cost Ashtari by 25 points (to reflect the change in Frostheart Phoenixes)
  3. Scalenex
    This too.
  4. Scalenex
    This three
  5. ASSASSIN_NR_1
    I could give High elves a shot, And the you could (Scalenex) pick what you think sounds good.
  6. n810
    You need to add that Lord Kroak and the Engine of the gods,
    hit ALL targets within range, even those in close combat
    and targets to the front, flank or rear.
    ASSASSIN_NR_1 likes this.
  7. ASSASSIN_NR_1
    Does the ark of sotek need the same clarification?
  8. n810
    Nope, I already says it can fire into combat. :D
    (I think it specifies the front arc as well)
  9. lordkingcrow
    lordkingcrow Active Member
    Considering that three of the four armies you've put on here are the armies I have (the fourth being the army I still want to make) I can only assume that you did this thinking about me. I think this is a pretty fair assessment of what needs to be fixed. I'm all on board for increasing the cost of cannons as well as going back to randomize what is hit.
  10. Scalenex
    I'm mostly done with a draft of the High Elves. I played on both sides of them before they got the new book and played them a bit after. Also they have an 8th edition handbook which makes tweaking them easier. I just need to figure out what to do with SC and give the first draft another look. Then it's on to Warriors of Chaos. Then I'm out of 8th edition handbooks that clearly indicate which units suck and which are overpowered.
    I should be able to do Orcs and Goblins because I play them a lot, but I haven't played a wide breadth of them. There needs to be some incentive to take vanilla Orcs and Goblins. The norm seems to be Night Goblins over regular Goblins and Savage Orcs over regular Orcs (same with Savage Orc Boar cavalry).
    Orcs and Goblins are not a top tier army so I would be reluctant to raise any points costs. Giants and Snotling swarms definitely need to go down. Not sure about the rest.
    EDIT: High Elves now up.
  11. Pinktaco
    maybe up the price of savage orcs and reduce price of regualr orcs? Like one points each maybe?
  12. ASSASSIN_NR_1
    Alright, I will send you might thoughts tough.
    And with SC I think Tyrion should increase in points. I mean he can have 4 ws 9 strength 7 attacks and movement 10, an AS of 1 and a 4+ ward, his only weakness is that he is toughness 3, but that's an army weakness.
  13. Scalenex
    Hmm, I actually lowered his points cost based on his treatment on the Ulthuan 8th edition handbook.
    You have certainly convinced me not to lower the points cost but I'm not sure his cost should be raised. It's not uncommon to see Armor save 1+, Ward save 4+ characters. Movement 10 is not useable unless he deploys solo in which case he is an exposed target without a cavalry bus.
    P.S. The proposed HE list is up right now by the way.
  14. Putzfrau
    Putzfrau Active Member
    No change to carnosaur?
    Not a huge fan of the lizardmen changes. The point reductions/increases feel a little all over the place and not very reflective of what it does to the army. Example: Trog is simply not going to be good as is, unless its just stupidly cheap. The point decrease does nothing to make it more usable.
    It feels like the army would be weaker overall after these changes. More options on whats you can reasonably take, but much weaker.
    Qupakoco likes this.
  15. Scalenex
    I was on the fence about whether or not to make Carnosaurs cheaper. I feared non-LM would look at the Lizardmen proposed changes with a magnifying glass, so I figured to be conservative with giving our scaly boys goodies.
    Also, Carnosaurs get a boost indirectly by making it harder to kill both mount and rider simultaneously with template shooting.
  16. Putzfrau
    That makes sense. I'll be honest, the more i read about all this 8.1/openhammer/ninth hammer stuff the more I'm disliking it.
    And i can't quite place why. Oh well. Either way, awesome work. This is very extensive and nothing really jumps out as being atrocious.
  17. Scalenex
    Not atrocious is high praise indeed. In any event I think your intial post holds wisdom and I slightly reduced the price of Carnosaurs and increased the discount o Troglodons a bit.
  18. Putzfrau
    Haha, that was the attempt even if it didn't come across in the best way :)
  19. Scalenex
    The intent was clear. I have been a moderator long enough that I can speak Forumese pretty fluently.
    On an unrelated note. I am reconsidering the point increase on Scar Vets and Oldbloods. It's Cold Ones that the ETC limits. Maybe a modest increase in Cold One character mount costs.
  20. Putzfrau
    I think that sounds very reasonable.
