AoS question about weapon stat lines
Discussion in 'Seraphon Tactics' started by ILKAIN, Jan 30, 2019.
  1. ILKAIN
    ILKAIN Well-Known Member
    Members,
    I am evaluating a couple of different weapon options and am trying to figure out if it is better to have a 1 better to wound, or a -1 rend? specifically, with all other stats the same the weapon statlines in question are:
    4+/4+/-1/1
    vs
    4+/3+/-/1
  2. LizardWizard
    It depends on the save value of the units are targeting. Against a unit with a 3+ the rend is better. Against a unit with a 5+ the extra to wound is better.
    Two additional things to consider:
    • Some units who are under the affect of buffs to their saves, such as the one provided by the Lord Castellant, are greatly hampered by rend -1.
    • Skeletons are everywhere in the meta. Rend -1 leaves them with only their Deathless minions save. You will almost double the number you kill by just having rend -1.
  3. ILKAIN
    so does a 4+ save make them equal (assuming none of the specials you mentioned)?
  4. LizardWizard
    If not equal they are nearly indistinguishable. You always end up with a fraction for the value. So who knows which side it would favor in reality.
    Paradoxical Pacifism and ILKAIN like this.
  5. Torxhol Drakescale
    Torxhol Drakescale Active Member
    Ideally you can manage to pull out both, but faced with a choice I tend to go with rend.
    Edit: I can generally trust my own dice to carry me through the hit and wounds, and I find that messing with my opponents rolls can sometimes be more beneficial than buffing myself.
  6. Aginor
    Another small thing to consider:
    If you know that you will face Nighthaunt on a regular basis, better go for damage. Rend doesn't work against them.
  7. LizardWizard
    There are lots of LoN running chainrasp hordes.
  8. Aginor
    Yeah, that too.
  9. Killer Angel
    what a mistake from GW's part, to include the new nighthaunts into LoN...
  10. Canas
    As a general rule:
    Rend is more effective the better your opponent's save is.
    +1 to wound is more effective the worse your base-value is.
    E.g. -1 rend has a larger relative effect going from 2+ to a 3+ (going from 1 in 6 failed saves to 1 in 3, doubling how many fail) than it'l have going from a 5+ to a 6+ (going from 4 in 6 to 5 in 6, only increasing the failed saves by only 25%)
    This leads to the following funny looking table:
    - Good save, Bad wound (e.g. 2+ save vs 5+ wound): both will give roughly equal improvements
    - Good save, Good wound: Rend will be more effective
    - Bad save, Bad Wound: +1 to wound will be more effective
    - Bad save, good wound: both will again have fairly equal results
    - Save and Wound both at 4+: both are equally valuable (assuming no re-rolls or other nonsense of course)
    Where a "good" would be 2+/3+, and bad is 5+/6+.
    MackiMac, Aginor and Killer Angel like this.
  11. ILKAIN
    that is definitely a funny looking table. thank you.
    Canas likes this.
