Blog Ritual's Army - Lizard on Lizard Action (For the Waaaaagh!)
Discussion in 'Painting and Converting' started by Ritual, Mar 7, 2017.
    We aim to please! :D
    Bowser and Ritual like this.
  2. Ritual
    Ritual Well-Known Member
    Missed the PS!
    It's a Hurricanum, Luminark, and Wizard griffon... All the pews.
    Jorgik, Crowsfoot and Bowser like this.
  3. Crowsfoot
    What the hell are you doing at 4:45 in the morning!
  4. Ritual
    Not sleeping -_-
  5. Warden
    That's a lot of fire dwarfs!
    Ritual likes this.
  6. Ritual
    Been a while since I updated, the move has kept me busy and I am currently internetless at the house due to BT needing to do external cabling somewhere, and it's a signal black hole.
    Here's a rough update:
    Warlord's Challenge
    33 Dwarves and 1 Magmadroth built.
    Waiting for my basing materials to arrive so I can do all the bases at once and get everything glued on before I start painting, I prefer working that way than doing the models separately, I find that the colours seem more cohesive somehow that way.
    Other "Legion of Doom" stuff
    Decided I am going to magnetise the Celestial Hurricanums so I can switch them both between that and Luminarks, looks like an easy one as the whole top part is interchangeable. Also going to magnetise the wizards and give them 32mm bases as well so they can either be on their vehicles or alone.
    Decided on all the wizards going on 32mm instead of 25mm so I have more basing area to play with. I do like me some bases.
    Seraphon
    Been woefully lazy with anything Seraphon related, having fun painting other stuff for now and need a break from the red and gold... I'll get back to them in a while.
    Next update regarding the internet is going to be on the 17th, so probably won't get any pics up for at least another week.
    Not dead though, just smell that way.
    Crowsfoot, Jorgik, Aphotic and 2 others like this.
  7. Ritual
    18300026_1508465252517205_8263478083495919616_n.jpg 18382606_400925133627244_8066831923516801024_n.jpg
    While I was waiting for the arrival of some basing materials I decided to build all my wizards (so far) - some subtle conversions and adjustments into their standard build forms and loadouts to hopefully reflect which order they represent.
    The fire wizard is the main attraction so he got a little bonus from the bits box to reflect his time spent with the Fyreslayers learning about the Magmadroth and the relationship he built with both the beasts and the Fyreslayers themselves.
    There's a story building in my head surrounding the army, so that's good.
    The final two wizards are both going to be non-standard, probably proxy from Bad Squiddo as I want two female wizards to fill in the gaps now, one druidic in nature, and the other who looks like she messes with the weather. Watch this space.
    Jorgik, Warden, Crowsfoot and 3 others like this.
  8. Ritual
    Crowsfoot, Bowser and tom ndege like this.
  9. Bowser
    The wizards look awesome! Spellweaver would be cool too.
  10. Ritual
    I ordered the Spellweaver yesterday, and build Saih. Also finally got started on the bases! Got loads to make though so running out of space...
  11. Crowsfoot
    I think i'm back on painting next week....
  12. Ritual
    Diablo 3 says no!
  13. Aginor
    ....but nobody listens since the game is boring. :D
    Ritual, Bowser and Crowsfoot like this.
  14. Crowsfoot
    Not really, it is leveling but once into the torments it's quite good, thing I like best is you can just bash heads then walk away.
  15. Warden
    Your wizards look good so far, I am looking forward to seeing them painted.
    The Empire Wizards kit is one of my favorites in the entire GW range, so much so that I bought a set for my Bretonnians to be my hedge-wizards. So many customizable options, I am glad you made so many different ones!
    Ritual and Bowser like this.
  16. Ritual
    Yeah, it's a great kit!
    I mixed it up and used a lighter to melt some bits into position which weren't meant to go and used some green stuff... And used alternate heads from the Hurricanum kit to mix it up further, so they should all look different. With Saih and a Spellweaver to go in for the last two it should be a good looking set of wizards once I get cracking on them!
  17. Ritual
    18382181_404145783317388_1799421529851691008_n.jpg 18382426_411765395856807_1840472122892222464_n.jpg 18443448_1907768729495757_225936746016145408_n.jpg 18513025_296125900792812_6430338685253713920_n.jpg
    Just got the 2 wizards to magnetise, and then work out how I'm going to cut the larger oval bases to size.
  18. Seraphage
    Seraphage Well-Known Member
    Gotta love those bases ! I'm buying mine asap ! At the very beginning of your magnetizing experience how hard was it? I intend to start pretty soon myself but I 'm a little scared I 'll be destroying my miniatures !
  19. Ritual
    It's easy enough... I drill out a little hole using a hand drill (I think GW sell them, got mine on ebay for cheap) and then bore out the hole was required... Carefully...
    Then I stick the magnet in with superglue (making sure its the right way around) - and then cover it over with green stuff as well before priming.
    Overall, it's fine. Just take it easy and be prepared for the hand drilling part to take a long time as it's not the quickest process and you don't want to apply too much pressure - let the drill do the work.
    Bowser, Crowsfoot and Seraphage like this.
  20. Seraphage
    Thanks a lot, will do !
    Jorgik, Ritual, Bowser and 1 other person like this.
