AoS saurus cavalry and skink starpriest
Discussion in 'Seraphon Tactics' started by dwarfepic, Apr 23, 2016.
  1. dwarfepic
    dwarfepic Active Member
    Guys, this has been a subject that I have been pondering on for a while now. I was thinking is you get six to wound on knights with lances, and they're in the firelance starhost, does the amount of mortal wounds get doubled to four from the base one, the additional one for the starhost and then doubled by the starpriests celestial venom. Or does the first single mortal wound get doubled to two and then one is addend from the starhost to three mortals. Either way this is a very powerful thing and can be very useful for line-breaking!
  2. Bowser
    I believe the two things happen separately so it would be 3 wounds, but you are correct, it's a fantastic line break!
    dwarfepic likes this.
  3. Killer Angel
    Sadly, it doesn't work.
    Blazing Lances: If the wound roll for a Celestite Lance is 6 or higher, the attack inflicts an additional mortal wound
    Serpent Staff: ...whenever models from that unit attack with their bite or jaws, a wound roll of 6 or more causes twice the normal amount of Damage
  4. n810
    doesn't that unit get a bite attack as well,
    so there is at least that...
  5. Tlac'Natai the Observer
    Tlac'Natai the Observer Active Member
    Basically, if they charged in the same turn, and also have the Serpent Staff buff, then every wound roll of 6 does something special!
    n810 and dwarfepic like this.
  6. Ixt
    Ixt Well-Known Member
  7. Killer Angel
    Slightly OT, but, now that I think on it, I realized another nasty combo.
    As said, when you buff a unit with serpent staff, whenever models from that unit attack with their bite or jaws, a wound roll of 6 or more causes twice the normal amount of damage.
    When Kroxigor jaws roll a 6 to wound, the damage is not "1", but it's a contest between a d6 from the kroxi and the target, and if the kroxi wins, the difference is the damage it deals. With SS, you could potentially deliver 10 wounds!
  8. Huanchi
    Huanchi Active Member
    I prefer the bonus from the bloodclaw starhost.
    Every bite or jaws attacks increase by one. Then you use the command ability of the scar vet on cold one on the knights. With this they made 4 cold one's bite attack. With the SP buff on sic to hit the do double the damage. With tis combo you have a unit (minimum 5 models on it) that starts with 4 attacks per model that will do double damage with the 6 on the hit roll. If you field a sunblood they can repeat hit rolls of 1
  9. Killer Angel
    I fear there's a little confusion, here.
    AFAIR, The BloodClaw starhost gives an additional attack only with the "powerful jaws and shield"
    with the ScarVet you'll have, for each knight:
    1 attack with the lance
    2 Attacks with powerful jaws
    3 Attacks with CO's bites
    The Sunblood, then, let you repeat all failed To Hit.
    The Serpent's Staff doesn't let you do double damage on 6 on to hit, but on to wound
    Bowser and Huanchi like this.
  10. Huanchi
    Sorry for the mistakes. Now i read again the formation. Thanks for the correction
    Killer Angel likes this.
  11. Killer Angel
    Don't worry. The idea is nice...
    We’re talking about 5 attacks for each model that can benefit from the Staff.
    5 models deliver 25 bite attacks, rerolling failed to hit; you probably will end rolling three or four 6s " to wound "
    Huanchi likes this.
  12. Huanchi
    I used it a lot of time. And every time my cold ones make me happy.
