AoS Saurus knights building
Discussion in 'Seraphon Army Lists' started by Bush4321, Dec 3, 2019.
  1. Bush4321
    Bush4321 New Member
    Just back building and painting WH after a break of almost 20 years. Decided seraphon to start with. Really into them and looking forward to the challenge of collecting amd playing with them. But for the life if me im getting bugged by the add on accessories for saurus knights. What are the little mini snake things and where would they go? Cant seem to find any pictures online of any cold ones with riders using this piece. Any help please appreciated!
    Dr.Doom likes this.
  2. ASSASSIN_NR_1
    Welcome to the forum!
    NIGHTBRINGER will probably greet you with a Star Wars gif in not too long :D
    The snakes is just to spice up the base if you want.
    Alternatively they could be used to make jungle swarms if you were to play old school fantasy.
    Dr.Doom likes this.
  3. Aginor
    Welcome!
    The snakes are just for decorations. Use them as you wish. :)
    Dr.Doom and Bush4321 like this.
  4. ILKAIN
    ILKAIN Well-Known Member
    the snakes actually used to be a unit that no longer has a points value in Matched play but is still useable in narrative or WHFB play. they are the "Celestial Swarms" models. here is the free public PDF pamphlet that has the old models warscrolls (but no points costs) as well as the counts as models list for converting lizardmen to Seraphon
    Dr.Doom likes this.
  5. Lizerd
    Lizerd Well-Known Member
    They actually do have point values you can use in the warscroll builder. If you go under lizardmen to add units you can add celestial swarms as battleline. They are not incredible but they do cause a decent road block .
    Dr.Doom likes this.
  6. ILKAIN
    warscroll builder is known to "find" points for things that haven't had any assigned to them officially. id be skeptical about that cost and their use in Matched play games
    Dr.Doom and Lizerd like this.
  7. Lizerd
    Fair enough, my guess then is to probably ask the person in charge and your opponent if it is ok to use them
    Dr.Doom and ILKAIN like this.
