7th Ed. Skink box
Discussion in 'Lizardmen & Saurian Ancients Discussion' started by denixrelic, Feb 4, 2010.
  1. denixrelic
    denixrelic New Member
    how many blowpipes do u get in a skink box,
    thx in advance
  2. msinosic
    msinosic New Member
    4 sprues that have 5 on each. 20 total blowpipes.
  3. Stegadeth
    Stegadeth New Member
    Which really bothers me. Dear GW, there is room on those sprues for 4 more measly blowpipes!
  4. n810
    Just cut the end off of the Javelins and call them Blowpipes. ;)
  5. denixrelic
    wow, really its 4 short, GW can never do anything right (just kidding, they put out a great product)
    oh well thats all i need. thx a lot for the info
  6. Stegadeth
    They're really hard to hollow out with a pin vice then. Yes, I am that dorky... but I think my blowpipes look cool!
  7. stubacca3291
    stubacca3291 New Member
    I recieved my skinks recently, set them up, until the last four, and was horrified to find I can't field 24 skinks with blowpipes, :(
  8. lazylizard
    lazylizard New Member
    so if there are only 20 blowpipes, how many javelins are there in a box?? 20?
  9. JohnMavrick
    JohnMavrick New Member
    Actually there are enough shields and javalins to field a full 24 man unit. Go figure, the configuration we DON'T want!
  10. Woutah
    Woutah New Member
    i think it's a subtle hint from GW that we should use javelin skinks :)
  11. destroyerlord
    destroyerlord New Member
    if you look though there is 1 brave head in each sprue of bodies (its the 1 with the metal tip on its crest) so the idea is that you can make 20 normal skinks and some leaders for units hence not having enough blowpipes, the braves would have hand weapons for foghting duels and stuff i think.
    But then im a noob so you can take what i just said with a pinch of salt if you want!!
  12. strewart
    And ironically, the blowpipe skinks are the skirmishers so won't have command. Its less javelins you can live with if you make command for a ranked unit.
  13. Calum
    Calum New Member
    do u get 20 blowpipes in the battalion than or just 12
  14. Vilicate
    Vilicate New Member
    Just 12 Skinks, and I think of those you only get 10 blowpipes.
  15. strewart
    Sounds about right. Essentially the battalion just comes with half the number of sprues as the skink box but they're exactly the same sprue.
  16. Calum
    Calum New Member
    i thnk thats abit annoying its the same with alot of sets that you dont get anough of 1 but get more than anough for he other
  17. destroyerlord
    What do you guys use for command? You get a brave on each sprue but what about musicians and standards? In skirmish units its not a problem but im planning on a few units of normal skinks and need ideas for command.
  18. Ilnar3
    Ilnar3 New Member
    The stegadon box has 2 banner arms in it,
    I tend to use a horn, from the COR sprue normally and stick it on a blowpipe arm, again, the one from the steg works lovely, there's nothing stopping you from using a javelin arm and a bit of cocktail stick or brass rod to make a banner arm though,
  19. Rated G
    Rated G New Member
    I gave my skink musician maracas.
  20. boreas
    boreas New Member
    Pure... Genius... :D
