AoS Skirmisk and Starpriest
Discussion in 'Seraphon Discussion' started by General Grivious, Jul 18, 2019.
  1. General Grivious
    General Grivious Member
    Hi people
    A question about the spell of the starpriest:
    This affect all units Within 15“???? How the magic works in Skirmish?
    Thx ✌️
  2. LizardWizard
    Which spell, Summon Starlight?
  3. ILKAIN
    ILKAIN Well-Known Member
    Summon starlight affects a single unit within 20". I am aware of no stipulations in Skirmish that would change that... but I also don't skirmish very often.
  4. Aginor
    I vaguely remember a rule (or was it a proposed rule?) That changed something about ability or spell ranges in Skirmish.
    Might have been in the White Dwarf of.. January IIRC that had the new Skirmish rules.
  5. LizardWizard
    Skirmish had some comprehensive rules changes in this past January's White Dwarf.
    ILKAIN and Aginor like this.
  6. General Grivious
    Yes Summon Starlight
    I understand in Skirmish there is no more « unit » but single models so what did it work?
    Oh! I don’t find that rule :c gonna search !
    Thx all ✌️☺️
  7. VVolfsong
    VVolfsong Active Member
    It will only affect a single model, since every model in Skirmish is considered a separate unit.
    I haven't read the mentioned White Dwarf issue so I don't know if there is anything written there that changes this.
  8. Satt
    Satt New Member
    So going by this you get a blot toad per Ripperdactyl? Seems like that'd be some strong area denial.
  9. VVolfsong
    No, they only count as separate units while in play. When you buy them they're all from the same warscroll, so you only get one Blot Toad.
    Similarly, you can only have one Alpha Talon regardless of how many Saurus Warriors you field.
    LizardWizard and Satt like this.
  10. Byte
    Byte Member
    Hello everybody.
    Skirmish rules? What is this? Is there a thread that I can read about this question?
    Thanks.
  11. ILKAIN
    I don't believe there is a thread, but there is the entire publication released by GW for Skirmishes.
  12. Byte
    Byte Member
    Ok, now I understood. Skirmishes is another Game different than AoS.
    Sorry for the confussion.
  13. Aginor
    It is reasonably close though, most rules are the same.
    The main differences are:
    - every model is its own unit
    - different point system
    - different way to make battleshock tests
