8th Ed. Solar engine irresistible force
Discussion in 'Rules Help' started by EricM, Dec 6, 2014.
  1. EricM
    EricM New Member
    Hi,
    if you roll irresistible force while casting beam of chotec, does the solar engine crumble like any other object with bound spell?
    Thx!
    Eric
  2. LawGnome
    LawGnome Active Member
    Nope. It is an innate bound spell, it gets cast irresistibly, and is ready to go again on the next turn.
    Scalenex likes this.
  3. Carnosaur Nr1
    Carnosaur Nr1 Member
    I thought it couldnt be fired on the time it got the irresitble force but it could cast the next magic phase
    Nope... it goes off and can't be dispelled. Best of all, like LawGnome pointed out, since it is an innate bound spell it doesn't crumble. You get all the benefits of irresistible force, without any penalties.
  5. Scalenex
    If it were a magical item, it would never be destroyed after the casting, but it's innate to the model so the bound spell can't be lost. Same with the Anvil of Doom and Empire Battle Priests and the Empire's magemobiles. Some army book bound spells do cause problems on a miscast like the Wood Elf Sisters of the Thorn, but we are in the clear with Solar Engine.
    This causes confusion. Don't let your opponents try to say you can't use the Solar Engine again.
    n810 likes this.
  6. GreenMachine
    GreenMachine Member
    Or the casket of souls. Irrestible force just means they can't dispel it and it's ready to go again next turn. Whereas something like the ruby ring of ruin will crumble after getting an irrestible force.
