AoS Starborn FoS
Slikus Vaw
Active Member
Messages
120
Likes Received
121
Trophy Points
Was wondering which of these lists is better. I don't really get to play too much so I cannot test these out till the tournament in my area kicks back up. I also haven't played a big tournament yet but I really want to. I'm trying to put more numbers in my lists... Trying haha. Any advice is appreciated
Leader
Kroak 320
Oracle 260(incandescent recticies)
Oldblood 110
Sunblood 130(serpant God dagger)
Battleline
Guard x10 200
Warriors x20 200
Warriors x20 200
Warriors x 10 100
Other Units
Kroxigor x6 280
Battalions
Sunclaw 160
Or
Leader
Kroak 320
Oldblood 110
Sunblood 130(serpent God dagger)
Battleline
Guard x5 200
Warriors x20 200
Warriors x20 200
Warriors x 10 100
Other Units
Kroxigor x6 280
Battalions
Sunclaw 160
Endless Spells
Bound Lifeswarm 60
Baelwind 40
Or
Leader
Kroak 320
Oracle 260
Oldblood 110
Starpriest 120
Priest 70
Battleline
Guard x10 200
Warriors x20 200
Warriors x20 200
Other Units
Kroxigor x6 280
Endless Spells
Bound Lifeswarm 60
Baelwind 40
With this army set I have 3 battle groups to take 3 key locations one is the Oracle with kroxigors(priest or 10 warriors) then the oldblood nd sunblood with the 2 20 warriors then then having the guard squeeze by on the edges nd once in position LoSat kroak in next to them.
I actually toyed with some similar lists (with all saurus), and found out there's not much point in Fangs of Sotek if you're not going to have any skinks. It might be better to just pick Dracothion's Tail if you you're going with starborne.
There's no point picking the Eternal Starhost. It's only available when building REALLY big armies (like 5000 points at least). Did you mean to pick the Sunclaw Starhost? That seems to fit your unit choices.
If I had to pick a list, it would probably be the second one. It's always nice to try the endless spells. But, you might consider dropping down to 3 kroxigors and adding more warriors; maybe 20/20/20 or 30/20/10.
Ah shiit ya I ment sunclaw, man my dyslexia fucks me up sometimes lol.
Ya was thinking about taking some kroxigors out but might make that flank be too weak but that might work in my advantage cause they will underestimate on the flank cause of kroaks nd slanns ablity to cast their spell thru the Oracle anywhere on the battlefield. Kinda want to make a list that takes advantage of it.
Ya I was thinking the same thing with FoS but thought maybe the artefact would be worth it. I would bring a shadiwstrike but I don't have any terridons or rippers yet.
So if I take out the warriors the oldblood nd sunblood nd put skinks instead how should I spend my points?
I think I have a good starborn DT list
LEADERS
Lord Kroak (320)
Skink Starpriest (120)
Skink Starseer (140)
Saurus Astrolith Bearer (140)
UNITS
5 x Saurus Guard (100)
10 x Skinks (120)
- Boltspitters Celestite Daggers & Star Bucklers
10 x Skinks (60)
10 x Skinks (60)
10 x Skinks (60)
6 x Kroxigor (280)
6 x Kroxigor (280)
ENDLESS SPELLS / TERRAIN / COMMAND POINTS
Bound Aethervoid Pendulum (60)
Bound Quicksilver Swords (40)
Balewind Vortex (40)
Bound Emerald Lifeswarm (60)
Bound Ravenak's Gnashing Jaws (40)
TOTAL: 1960/2000 EXTRA COMMAND POINTS: 0 WOUNDS: 139
I need the seperate skink units so I can put my kroxigors starseer starpriest astrolth nd a guard unit on side board nd teleport them 9" away after I teleport kroak in position a little farther away send one kroxigors unit in then hope for a double turn nd then send my other kroxigors unit flying over nd buffed with a 3d6 charged able to get 3" away
Back
Top
