AoS Starpriest with carnosaur
Discussion in 'Seraphon Discussion' started by Masterhobo, Jun 18, 2017.
  1. Masterhobo
    Masterhobo New Member
    If I run an Oldblood on carnosaur with starpriest and I use the star priests "Serpent Staff" ability will that double carnosaur jaw attack damage from 3 to 6?
    Crowsfoot and Captaniser like this.
  2. Captaniser
    Captaniser Well-Known Member
    Masterhobo, Seraphage and Crowsfoot like this.
  3. Aginor
    Yeah. It is HILARIOUS when it works. Priceless faces of opponents. :D
  4. PabloTho
    PabloTho Well-Known Member
    Bear in mind that when you get the 'pinned down' bonus by hitting both of your claw attacks while fighting monsters, you'll get the double damage on a 4+ rather than a 6. A truly stupid amount of damage output if you roll well!
  5. Draconder
    Draconder Active Member
    I have to agree, last week I had my Saurus Oldblood on Carnosaur and used my Skink Starpriest on the Carnosaur's jaws. He instantly killed two Ogre heroes in one battle and my opponent was very shocked by the results. Nom nom nom ^www^
  6. Xlanax_lot
    Xlanax_lot Well-Known Member
    Yes, and there ara a couple of great combos to make ir even beter to use like the ones I will mention below
    Actually, I think you might be mistaken there as the +2 for the pinned down ability is a modifier of the to hit roll and the serpent staff requires a 6 to wound.
    But worry not after much encouragment from @Crowsfoot to paint my carnosaur... I started painting him and as a result I came uo with the following 1.5k pts list, not aure how competitive is but I think it sinergises well;
    2 x Oldblood on Carnosaur
    - reckless + Relic Blade
    - Relic Blade
    1 x Starpriest
    1x Astrolith bearer
    1x Loremaster of hoeth
    3 x (10) Skinks
    1 x (3) Ripperdactils
    Shafowstrike host
    I like this combo because
    1. Use thecommand ability to give both carnosaurs +2 Attacks with the jaws
    2. Give double damage to oneof them
    3. Plant the standard to rerrol hits and get -+1 to cast
    4. Cast hand of glory in one of them (rerroll to hit and to wound) Note: this one can be changed fo a beast battlr mage wich gives a + 1 to wound making the double damage twice as likekLy
    - big battleshock isue
    -shadowstrike to hold enemies and bouble rap
    What do you thibk
    Masterhobo, Aginor and Seraphage like this.
  7. Seraphage
    Seraphage Well-Known Member
    I like the thinking behind this list. It could definitely be tried ( will do at some point, Arrg so little time, so many lists to be tried )
    Nefertem, Masterhobo and Xlanax_lot like this.
