AoS Stegadon or Saurus Knight
Discussion in 'Seraphon Army Lists' started by Iblitz, Oct 2, 2017.
  1. Iblitz
    Iblitz Well-Known Member
    For some reasons i'm block on some choices to fit my 2k list.
    In order to make a 2k skink list, i'm planning to do something like this :
    Skink starPriest
    Astrolith
    10 skinks
    40 skinks
    40 skinks
    3 salamandres
    3 handlers
    Camé
    6 rippers
    Shadowstrikes
    But right now, i'm think : what about some diversity in my list, and what about a Saurus knights ? (which can become skinks riders easily)
    So instead of the seconde stegadon and the 10 skink units, i'll put 10 Saurus knight + one oldblood on cold one.
    I think, 2 stegadons is far better, much stronger, solid.
    But riders have more hp, better moves and could provide some extra attacks (specialy the oldblood).
    The second list looks like this :
    Oldblood on coldone
    Skink starPriest
    Astrolith
    40 skinks
    40 skinks
    10 knights
    3 salamandres
    3 handlers
    Camé
    6 rippers
    Shadowstrikes
  2. Aginor
    I don't think the Knights are worth it except in a Firelance or as part of a Saurus army in which they get done more buffs.
    The Stegadon is a mighty beast, his long range can help you snipe dangerous heroes, and his ability to command Skinks also comes in handy in a Skink army.
    I would probably go for the Stegadon.
    Tizianolol, Seraphage and Paul Beenis like this.
  3. Killer Angel
    I'd second @Aginor. Without the starhost, it's steggy all the way!
  4. Paul Beenis
    Paul Beenis Active Member
    I found using a Stegadon for the first time, teleporting in, moving d6 and then charging into elites with -3 rend was very good when we lack MW output! also units of 40 skinks are invaluable, I've just bought more :D but don't rely on them as a backbone in your army to be able to kill everything!
  5. Iblitz
    I was thinking about Kroxies (by 6) but whithout the thunderquake thing, are they reliable ? they cost less today.
    Forget about that Idea, Tp Stegs is awesome enough... :D
    Of course, this one, will have some flame throwers.
  6. Killer Angel
    I did it against a group of Kurtnoth hunters.
    3 hits at 3+, rerolling 1s.
    I rolled three 2. :p
    I need to sacrifice to the dice God.
    Paul Beenis and Seraphage like this.
  7. Robertxtrem
    Robertxtrem Active Member
    2 millions seems like a lot of points!
  8. Aginor
    I'm quite sure he didn't mean to write 2000k but you have to admit that would look awesome! That would be a whole room floor covered with models. :D
    Paul Beenis, Seraphage and Joshmunga like this.
  9. Robertxtrem
    399980 skinks and 1 starpriest
    Xasto, Aginor and Joshmunga like this.
  10. Iblitz
    Edit. 2000k was a bit too much. I don't have enough time for that. 2K should be enough. :D
    does anyone tries the TP Stegadon with flamethrower ?
  11. Aginor
    I probably will as soon as my Orruk playing friend has assembled all his Savage Orruk Archers to kill me with them. Teleporting the Flamodon might be a funny counter for them.
    Paul Beenis likes this.
  12. Solaris
    Solaris Member
    The Steggy teleport looks awesome. With two of them, you clearly need the Slann general for double tp as well!
  13. Paul Beenis
    Just remember activations! He will hit one of them before you hit back
    Seraphage and Killer Angel like this.
  14. Killer Angel
    Yeah.
    If you plan to double teleport + charge with 2 stegadons, you should buff with magic just one of them:
    Steggy A: mystic shield + Starlight
    Steggy B: nothing
    You attack firstly with B, then with A
    Seraphage, Paul Beenis and Solaris like this.
  15. Aginor
    Either that or use the second teleport for a support unit. Astrolith Bearer might be a bit risky if you don't have other units near but it could be fun. Razordons would also be an option. If the Stegadon doesn't make the charge they might protect him from the counter charge. If he does make the charge they can still provide fire support.
  16. Paul Beenis
    Or better still use the double teleport for the aggressive charging units and the summon for the supporting units! If you can work it so you're in range :D
