AoS Stegadon vs Engine of the Gods
Discussion in 'Seraphon Tactics' started by kokocitka, Feb 5, 2018.
  1. kokocitka
    kokocitka New Member
    Hi
    I've recenty bought a stegadon set and decided to assemble it with skytreak bow.
    But after the gw faq and EotG rework i felt really confused.
    Now the EotG is much more useful, but the chance to roll 18 without slann is really low(~0,5%) and even skink starpriest help only a bit(~8% chance).
    In my army I have:
    Saurus oldblood on carno
    Saurus scar veteran on cold one
    10 saurus warriors
    5 saurus knights
    20 skinks
    Saurus astrolith bearer
    Skink starpriest
    Skink priest
    Is it worth to assemble stegadon as engine or i should use skytreak for my army? Thanks for help.
  2. OnlyPerfect
    OnlyPerfect New Member
    For what you have I would run Stegadon with skystreak. Personally I feel that running EotG without proper support is just sub-par and unreliable. Not to mention that you don't have anything to snipe or really handle big blocks the stegadon can do both to a degree.
    If you plan to expand your list though I would look at more warriors for sure. 10 won't do anything but be a slight speed bump for most units.
  3. kokocitka
    Thanks for your reply.
    You are right. I will build my stegadon with skytreak and glue down the eotg priest to 25mm base to have second priest model. I'll also use eotg ring for some conversions or maybe a piece of terrain.
    Probably i will expand my army with unit of 40 warriors with spears. I've got 10 now because of start collecting.
    crazyeye45 likes this.
  4. Aginor
    You can even make the Steggy convertible between all versions!
    I did that, and I am happy with it.
    But I agree, I would go for the Bow Steggy first. It fits into many lists.
    Seraphage and kokocitka like this.
  5. Killer Angel
    Yep, the Stagadon with bow is the most efficient version.
    Later, you can think about the Engine
  6. Crowsfoot
    Do what I did get 3 Stegadons and build one of each :D
    crazyeye45 and Killer Angel like this.
  7. kokocitka
    I want but I'm not as rich :D
