AoS Table top simulator
Discussion in 'Seraphon Discussion' started by Ustyk, Apr 7, 2020.
  1. Ustyk
    Ustyk Active Member
    In the times when nurgle infects everybody with coronavirus i found tabletop simulator on steam. You can play also AoS with seraphons. Has anybody any expiriance with it? Maybe sbd can guide me in inataling mods or rules.
    BTW on steam today ends discount
    LizardWizard and knave like this.
  2. Bartuk
    Bartuk Well-Known Member
  3. LordBaconBane
    I did a game with one of the Lustria members here. It's doable.
  4. Erta Wanderer
    just doable?
    ILKAIN likes this.
  5. ILKAIN
    ILKAIN Well-Known Member
    said like an offended girlfriend after a good romp :)P
    Canas and Ustyk like this.
  6. Erta Wanderer
    eh more asking for him to expand apon it. i've been waiting for people to try TTS and his report seemed underwhelmed
  7. ILKAIN
    I have tried it and have had difficulty using it. mostly I need to learn how to use multiple workshop mods at the same time, so I can have a decent battle ground AND have models.
  8. Davema
    Davema Well-Known Member
    It works grand. Our group has played a few games now, just as quick as real life once you get the controls down.
    Cuetzpal Pilli likes this.
  9. DeathBringer125
    Me! Also we found a couple things. Firstly if a model is cardboard cutout style try using the attach tool and dragging from their base to the cutout, alot of times they technically are two different models that just balance well, though they can fall off. Secondly if models aren't stand upright it's probably due to the map. Me and Bacon played a map where models would randomly flip. Also the the 3rd and final thing is to utilize bags for your lists. If you go to object- tools you will see a bag option. Drag it on board (with your factions models mod up) then drag every model inside. Once you do this right click the bag and hit save object. Then when you play with your friend you host a multiplayer world with the map, drag your bags onto the field, and unload your army. Pls note, if you skipped attaching the models to their base, the models will come out seperate, a base and the cutout.
  10. LordBaconBane
    Pretty much this. I'd like to add on a few things in point form though
    - I find TTS quite liberating. You can run any list you want from any army you want, provided someone has the models. I ran a Terradon list recently.
    - Once you get a handle on the controls, it runs pretty much the same speed as an in-person AoS game
    - I find TTS less fun because you can't talk to your opponent.
    - You can save armies as loadable objects
    - TTS is not well optimized, it will struggle a little if you're on an older machine
  11. DeathBringer125
    Technically there is an in game voice chat or even utilizing discord.
    Cuetzpal Pilli and LordBaconBane like this.
  12. Cuetzpal Pilli
    Cuetzpal Pilli Well-Known Member
    Question for you guys who've used TTS (@LordBaconBane @ILKAIN @Davema @DeathBringer125 and anyone else) : were you able to find good "renders/models" of the actual miniatures?
    I ask because in Caleb Hastings' review vid for Kroxigors (would link but at work and can't access YT), he uses TTS to try and show the range of the Moonhammer against a smallish mob of plague monks and he had managed to find the TWW2 Kroxigors. Kinda hoping that someone, somewhere had managed to create renders of all/most of our units using the TWW2. But if not, what did you guys find/use?
    Not sure if they're purchased or what-not so that may be a good note to add.
    (If TTS & this thread picks up enough steam might be good to sticky it somewhere and let people know about/share the model files they find. I'm sure the admins will do this if it gets to that point ;).)
  13. ILKAIN
    Caleb hastings is @Caleb ex nihilo here, just ask him yourself lol
  14. Cuetzpal Pilli
    Ah, sweet! Might do just that! Thx!
    DeathBringer125 likes this.
  15. DeathBringer125
    The mod I use for Seraphon is called something on the lines of Lizardmen 2d/3d. It has some nice TWW 3d models
  16. A_Reptile_Dysfunction
    A_Reptile_Dysfunction Well-Known Member
    Is there any tutorial videos on how to set this up? I've downloaded the TTS on steam and managed to add the AoS mod with the 3D Seraphon models, but not sure how to start a game with dice/objectives/measuring tools etc. Any help is much appreciated!
  17. Tav
    Tav Well-Known Member
    If you search for AOS in the steam workshop you will find a template called DEIKNOS or something like that. has various boards, scenery battleplans and tools. you can build whatever map you want and play a game
  18. A_Reptile_Dysfunction
    Thanks dude, I’ll have a gander.
  19. Kilvakar
    Kilvakar Well-Known Member
    I've played several games over TTS so far, and while the controls do take some getting used to, once you get the hang of it it's quite fun. The cardboard cutout models are a bit annoying, but there are maps for all the basic battleplans and die rolling tools that make dice rolling actually faster than on regular tabletop. Measuring is a bit weird, though. A lot of the models have issues where their bases aren't mapped quite properly, and you have collision problems when trying to pile in or otherwise move models close to each other.
  20. Nart
    Nart Well-Known Member
    Seraphon have all their models in nice 3d. We are lucky in this matter.
    Cuetzpal Pilli and Kilvakar like this.
