Help Water Effect Resin
Discussion in 'Painting and Converting' started by Explodingzeb, Feb 5, 2020.
  1. Explodingzeb
    Hi all, I'm currently working on the square bases for my Saurus. I'm going for a swampy feel and I have some woodland scenics water resin. I'm just wondering what you all use/ would recommend to block off the edges of the base when using the resin?
  2. bOdziO Wolf
    bOdziO Wolf Well-Known Member
    I blocked the edges of the base with sand glued by PVA.
    How it looks before priming:
    Finished product:
    Warden, Imrahil and Explodingzeb like this.
  3. Explodingzeb
    That looks good, that was my plan for a few of the bases. However I'm trying to to do it on some so that the water is at the edge of the base. So I've built up a bank of sand part way into the base but want the water to go right to the edge. I've seen the effect done before but I'm a bit lost about what material to use to stop it at the edge that won't just get stuck to the resin.
    bOdziO Wolf and Warden like this.
  4. WildColonial Boy
    Try clear plastic or perspex
    Warden, Explodingzeb and Imrahil like this.
  5. childishknight
    childishknight Well-Known Member
    Honestly, I just used painters tape to seal the edges of my carno base. Some leaked out, but it worked for the most part. Not sure if it works on a smaller scale with sharp edges....
    Explodingzeb likes this.
  6. Explodingzeb
    So I attempted this using perspex and when I removed it it took half the resin off with it unfortunately. Trying again with tape now
