AoS What am I missing about Engine of the Gods?
Discussion in 'Seraphon Tactics' started by tag8833, Feb 10, 2018.
  1. tag8833
    tag8833 New Member
    It looks expensive and unreliable, and yet I see it in alot of lists.
    6-9 is good, but really swingy
    10-13 is very situational
    14-17 is usually bad. Do you auto-lose if you don't have reserve points?
    18 is great, but hard to roll.
    What is the thing I'm missing? It just seems too widely variable (even with a Slann) to be relied upon.
    Ritual likes this.
  2. LordRibbit
    LordRibbit Well-Known Member
    It can be fun to use, but I tend to take it with a slann and a starseer. Put curse of fates on it, with the extra dice and re-rolls it gives you quite a bit of control over it and increases the chance of rolling an 18 to around 19%.
    It can be quite good in cc too!
    HeirofCarnage, Ritual and Aginor like this.
  3. Aginor
    Aginor Well-Known Member
    Pretty much this.
    An EotG without a Slann is too unreliable to be of any real use IMO, but with a Slann it gets a lot better.
    And yes, rules as written means that 14-17 is crap in matched play.
    Ritual likes this.
  4. LordRibbit
    And the d6 mortal wounds doesn't need line of sight, get for sniping small support characters who tend to have 4-6 wounds
  5. Canas
    Canas Well-Known Member
    Meh, it's not just unreliable, it's outright unusable without a slann or curse of fates. The effects vary too much in what they do and the requirements they have to work to amount to anything consistently. It's entirely possible (and even quite likely) to have a game where none of the procs are actually effect. If they'd at least made it so all the procs had similar functions and restrictions itd be a hell of lot more useable.
  6. tag8833
    tag8833 New Member
    So lets say I have a Slann and an EotG. And for my Engine, I roll 4, 5, 5, 6. Which isn't all that bizarre of a roll on 4 dice. I've got no reserve points. Did I just lose the game?
    Ritual likes this.
  7. Aginor
    No you don't lose the game. The EotG just does nothing.
    Ritual and Canas like this.
  8. tag8833
    tag8833 New Member
    The way I figure it, most of the time, there are 2 useful results: 6-9 and 18.
    If you've got No Slann, and no Curse of Fates, your odds are:
    6-9: 32.87% MW: 1.15
    18: 0.46%
    Either: 33.33%
    If you've got Curse of Fates, but no Slann:
    6-9: 48.15% MW: 1.81
    18: 1.85%
    Either: 50%
    Slann, but no Curse of Fates:
    6-9: 60.49% MW: 2.11
    18: 1.62%
    Either: 62.11%
    Slann, and Curse of Fates:
    6-9: 72.69% MW: 2.65
    18: 5.79%
    Either: 78.47%
    So even in the best of scenarios, you EotG's is going to be worthless 1 in 5 turns. In an optimum scenario, the Mortal Wounds you can expect it to generate per turn are 2.65. That feels pretty underwhelming for how many points you've committed to it, though that might be understating it somewhat, because the 10-13 result can occasionally contribute, and it is hard to gauge the value of the 18 result.
    HeirofCarnage, Buldi and Ritual like this.
  9. tag8833
    tag8833 New Member
    To compare it to a Bastillidon's Searing beam. If you use Curse of Fates on the Bastillidon, it will do more damage to anything w/ a 3+ or worse save. EotG out performs Bastillidon's Searing beam vs things that have a 2+ Save.
    HeirofCarnage and Ritual like this.
  10. Canas
    In practise a bastillidon will probably still be better even against a 2+ as its far less likely to completly fizzle, while also having a higher potential when the dice favor you. An EoTG is quite likely to do nothing whatsoever, and wasting an entire turn will be quite costly. A bastillidon is far less likely to waste an entire turn worth of attacks.
  11. Killer Angel
    Killer Angel Well-Known Member
    I usually use the Engine only if i run the thunderquake starhost.
    Aginor and Ritual like this.
  12. Aginor
    Actually I would take a Troglodon if you play a Thunderquake without a Slann. It has the same save, more wounds, it is cheaper and moves faster, has more range on the ranged attack, debuffs enemy bravery (which is probably worth more than rerolling Skink Battleshocks) and it isn't much worse in melee.
    HeirofCarnage and Canas like this.
  13. Canas
    An advantage of a EoTG here though is that its a hero, and the rest in the thunderquake host isn't. The troglodon cant take artifacts right?
    HeirofCarnage, Buldi and Aginor like this.
  14. Aginor
    Oh that's correct. That might actually tip the balance a bit more toward the EotG.
    HeirofCarnage likes this.
  15. Slanntastic
    Slanntastic New Member
    I have been running the EotG because it seems to be (other than Kroak) one of our only options for significant mortal wound output. If you aren't taking Kroak or the Engine what do you do about those tough units (2+ save, anything with mirror shield, etc.)?
    I usually take the Slann with Vast Intellect to make it work but when I do that I am missing out on the 2nd teleport, which is a tough pill to swallow.
    Buldi likes this.
  16. Aginor
    The only other way to kill such tough units is massive shooting, preferably with rend (Bastis, Salamanders or Razordons reasonably close), or magic, and I occasionally used Terradons with decent effect.
    So yeah the EotG's mortal wounds are very useful in the current meta, I just wish it was a tiny bit more reliable without a Slann.
  17. Canas
    Get a bastillidon with ark of sotek. More reliable than an EoTG, less likely to die, and unlike the EoTG it actually fullfills a clear role allowing you to build your army around it being reliable.
    Also, terradons are vastly underrated, and again way more reliable. Only issue would be when they face range-heavy armies they might get blown up before being able to drop their payload.
    Apart from that mortal wounds are limited to kroak and our wizards (god we need some extra spells...) and Knights, and with teleports Knights might actually be a threat as you can cycle charge each turn now.
    Which leaves rend which we have on:
    Every saurus hero.
    Slanns
    Saurus guard
    Salamanders
    Everything that's bigger than a cold one
    To be honest, we have a surprising amount of rend now that I look at it. And that's without battalions (e.g. sunclaw or a firelance) that could help. To be honest, outside of re-rollable 2+ saves with healing nonsense we probably shouldn't be as screwed as we appear at first glance...
    Seraphage, Slanntastic and Aginor like this.
  18. tag8833
    tag8833 New Member
    This is the sort of information I'm hoping for. I've been playing Sylvaneth, and am just starting up Seraphon. However, in my time playing Sylvaneth, the main source for 2+ saves is other Sylvaneth, and against them, 2 mortal wounds scaresly makes a difference, because they have heal mechanics that can heal faster than that.
    But, my meta is incredibly small, Does the wider game have alot of units with 2+ saves, where 2 1/2 mortal wounds pert turn will make a difference?
    ETA: My meta is so small, I've never played a destruction or death army. Lots of Order, a few Chaos.
  19. Seraphage
    Seraphage Well-Known Member
    Terradons my friend. 9 of those pretty fellas won me a big tournament ! :)
  20. Canas
    Sylvaneth are a fairly heavy on the healing I suppose. Most others tends to not have as much healing so 2.5 mortal wounds per turn actually sticks. However, such a low number of stable mortal wounds is unlikely to ever win you the match on its own, or even to kill the intended target. If you could bring say 4 EoTG then it might get somewhere, but seeing as you're unlikely to ever bring more than 1 it's unlikely to be more effecient than bringing say a starpriest and having him spam arcane bolt if all you really care about is the mortal wounds.
    In comparison look at Kroak. He has 3 attacks that deal mortal wounds, as opposed to 1, has better range, is more reliable, is more difficult to kill, 2 of his 3 attacks affect multiple targets and can be put on a balewind to increase every single one of these aspects even further. That's waaaaaaaaaaaaaay better than anything the EoTG really has to offer offensivly.
    Minor sidenote, why isn't the EoTG mounted by a starpriest or starseer or some other magical skink wizard? It feels like that thing should be a wizard.If nothing else, why isn't it mounted by a skink oracle or skink alpha like the troglodon or stegadon? Why do the skinks that ride it not do anything other than throw very ineffective javalins at people. Also, why is the stegadon carrying an EoTG weaker than a normal stegadon? the EoTG makes ver little sense the more you look at it..
    Buldi, Seraphage and Aginor like this.
