Hey there! Im fighting against the Dreaded Sky Duardin and I need to make a list! I currently have: Kroak Slaan Scar Vet on cold one Scar Vet on Carno Old one on Carno Astrolith Skink priest Skink starpriest EoTG 40 saurus 40 skinks 15 cold ones 3 terradons 1 God Emperor Bastiladon I will be facing: Ironclad Endrinmaster dirigible suit 3 skywarden 3 Endrinrigger Grundstok Apologies for formatting, im on mobile!
1000 points is tricky for seraphon as if you want to run the strong kroak stuff then it takes up about half of your army. The KO player really doesnt have a lot of capturing power. Overall i would suggest going for a simple coalesced, smash them in the face sort of build. Knights, starpriest, carnosaur and MSU skinks, maybe even a big saurus block, not a a lot they can do to shift you off of an objective Koatls claw Scar-vet on cold one Skink starpriest 10 saurus knights 5 saurus knights 40 saurus warriors 10 skinks 10 skinks the reduction in damage from being coalesced should temper the power of all of the shooting a bit. Basically you want to spread out and limit the effectiveness of fly high, you have multiple ways of scoring, even just 10 skinks sitting on a objective is more than his whole armies worth and you would have too many units for them all to be taken down
Not a bad list! My only worry is like it stopping power, the ironclad is a pain in the ass, and while coalesced defense helps a ton, I was scared it wouldn't do much, thanks for the list though! Ill be sure to try it out!
Unfortunately, in a 1000 point game, a big piece like the ironclad has a lot of power, moving around the board with less bodies to limit where it goes. If you get a chance then try and go into it with as much as you can but otherwise its not worth chasing. Take the objectives and get points
