8th Ed. 1000p friendly beginner army
Discussion in 'Lizardmen Army Lists' started by Jinxed Mojo, Mar 4, 2013.
  1. Jinxed Mojo
    Jinxed Mojo New Member
    Hi guys! I've decided to start collecting WHFB with three other friends, I have chosen to collect Lizardmen. We decided that our first goal will be to build a 1000point army each and battle with them. I've been experimenting on my own with different armylists, and in the end I came up with this one. No experienced player has yet checked it out or given me any feedback, so be gentle hehe :p . Here it is:
    Lizardmen 1000p armylist for the purpose of casual play as follows:
    Heroes: 250p
    Saurus Scar-Veteran
    Light Armour
    Enchanted Shield
    Obsidian Trinket
    Total 110p
    Level 2
    Dispel Scroll
    Talisman of Protection
    Total 140p
    Core:540p
    Saurus Warrior x19
    Spears
    Full Command
    Total 258p
    Skink x16
    Full Command
    Additional Kroxigor x2
    Total 212p
    Skink Skirmisher x10
    Special: 60p
    Terradon Rider x2
    Rare: 150p
    Salamander Hunting Pack x2
    Army total: 1000p
    Any constructive criticism is much appreciated. The idea is to let the Scar-Veteran join the Saurus unit, thus giving the whole unit a magic resistance(1) with the Obsidian Trinket. I thought this could be useful since I'm up against Dark Eleves, Skaven and Greenskins, and from what I've understood they all use a good amount of magic. The Skink Priest is to join the Skrox unit and follow them to the front line, while casting augment and hex spells to aid my troops in combat. Skirmishers will do the hunting/harassing, as will the Salamanders, and the Terradons will go for the long shots, like war machines or lone characters. What are your thoughts? :)
  2. Ferocious
    Ferocious New Member
    terradons have a minimum of 3 sorry :)
    sorry i meant terradons, i wasnt thinking very cleaerly
  3. Jinxed Mojo
    What do you mean?
  4. Rhodium
    Rhodium New Member
    What do you mean by this??
  5. Old Mossy
    Old Mossy Active Member
    For salamanders, doesn't matter what was meant, there is no rule where that's correct. If you mean terradons, though, he's right. Minimum of 3 per unit.
    Spears is probably not a great idea on your saurus with only 19 models, IMO. You'll lose those extra attacks pretty quickly.
    I'm not a big fan of champions in general, and can be more points than they're worth at only 1000 pts.
    For your skrox unit, 16 is a small meat shield. I like to take 20+ skinks for 2 krox, to have the extra protection.
    Take all that with a grain of salt, though. I've played terribly the last several games, and am definitely starting to think my tactics are flawed.
  6. david l
    david l New Member
    Purely for experimentation, taking both a wizard and a scar-vet makes sense, but I'm not convinced you will find both effective. Basically you don't have enough points to properly equip both, especially if you want that scroll. If you drop the scroll and take the priest with nothing, you can make a good scar-vet.
    Enchanted Shield is okay, but I would absolutely combine it with Dawnstone. Then you spend the rest of his points on either Sword of Might or Burning Blade.
    Obsidian Trinket is really not worth buying. Damage spells are not that common and a 6+ save won't make a clear difference anyway.
    Talisman of Protection is never worth buying. As above, I think you might be happier dropping the scroll for scar-vet equipment.
    Generally I don't think that is enough numbers to justify spears. They will often be missing out on spear attacks in the FIRST round.
    I agree that 16/2 SKrox is not enough skinks, but "not enough" is true of everything at this points level, so I'm not sure that is a priority fix.
    Not legal - min size is 3.
  7. Jinxed Mojo
    Oh how could I have missed that, min size is 3 terradons. Well that's embarrassing :shifty: .
    Considering the Hero problem, I want to keep them both, but I guess I'll have to undress my priest. And about the terradons, I think I'll just drop them. What about making it look like this instead:
    Saurus Scar-Veteran
    Light Armour
    Sword of Might (considering that I already know that the Greenskin player is gonna field netters, so I want to make up for the strength loss)
    Enchanted Shield
    Dawnstone
    Plaque of Tepok
    And then as said removing the Terradons, buffing up the Skrox unit 24 skinks and 2 kroxigors. Also bringing 2 extra handlers for my salamanders. According to my calculations I'm at 960 points now, and the Saurus Warriors are left as they are for now. I could either add some extra warriors, or I could remove some of them to make room for another 10 skink skirmishers to compensate for the terradons. Is this progressing in the right direction? As for now I don't have any special choice, but I guess when you're playing with low point armies you have to make sacrifices to gain advantages elsewhere.
  8. david l
    david l New Member
    Lizardmen special choices are not that awesome, so skipping them is not a problem. Different books have different strengths - if you skip High Elf specials, your army probably stinks.
    I would absolutely increase the Saurus slightly.
  9. Qupakoco
    We have to buy both the Sword of Might and the Enchanted Shield at the points cost listed in our book, not the BRB. The sword doesn't really make a difference, but the shield puts you over your 50 point cap on magic items. Swap that puppy out for the Charmed Shield.
  10. Jinxed Mojo
    Thanks for all the advice! I'm tweaking and experimenting with some points to make the most of them, but since me and my friends are new to this game, I will not try to make it too competative, more like holding it on a casual level. But that doesn't mean I don't want to win hehe. All your advice are taken to consideration, and I'm working on making the best of it!
