AoS 2.0 Battletome: Seraphon Errata is out
Discussion in 'Seraphon Discussion' started by Nart, Jun 27, 2018.
  1. Nart
    Nart Well-Known Member
    In short:
    - added summoning rules from GHB for unused spells and EotG;
    - Paragon of Order can be used only once on the same unit per turn;
    - Thunderquake effect declared in charge phase. Suprisingly I found no other changes;
    - Starbeast Constellation gives +d3 CP at the start of the battle;
    - if Scar-Vet's on Carno CA used on unit twice, it generates two bonus attacks on 6's to-hit rather than 1;
    - toad can be placed even if Rippers in Reserves;
    - Light of Dracothion is 15" even if used by Slann;
    - obviously, core rules from the battletome no longer used.
    I attached PDFs. You can check it on community site by yourself.
  2. pendrake
    This is errata for the GHB that comes out on the 30th?
  3. Nart
    No, this one is for Battletome: Seraphon.
  4. deepstriked
    deepstriked New Member
    When you summon a unit with EoTG the can move normal in the following movement phase? because nowhere in the warscrolo of EoTG writes that that was the movement of the unit for the following movement phase ??? Also if you summon ripperdactyls in the first hero phase with EoTG you can use bload toad normaly ?
  5. Dr Kaos
    Dr Kaos Member
    It doesnt say when in the hero phase you place the Blot Toad so I guess you could place the toad(s) after EotG have summoned.
  6. Aginor
    Yes to both as far as I understood it.
    DarkMatter likes this.
  7. LizardWizard
    What happens if you summon Ripperdactyls post the first Hero phase of the game? Are you still able to place a blot toad?
  8. Dr Kaos
    Dr Kaos Member
    Nope. The toads can only be placed in your first hero phase. Therefore it can be a good idea to bring some ripperdactyls from the start.
    Nart likes this.
  9. LizardWizard
    I suppose you could bring multiple Ripperdactyls units allowing you to spread out your Blot Toads so that any of your units may benefit from them.
