AoS 2000 points of Koatl's Claw
Tle'azqa'ecl
Active Member
Messages
68
Likes Received
111
Trophy Points
Hello!
I've once again been lurking for quite some time, due to work and family, but now that I finally got the new Battle Tome I figured I'd give it a go once more. I feel more drawn towards the Saurus Warriors and the big beasts, would've loved to fit in a unit or two of Kroxigors as well, but alas. I know for a fact that I won't win any tournaments, but this is just for casual play.
I am a bit stumped regarding how many command traits I could dish out among the characters. Can each of them take one? And what about artifacts? I've given my Scar-Veteran the Eviscerating Blade because, well, he has to if I am to run Koatl's Claw.
Constructive criticism and comments are always much appreciated! Thanks in advance!
Coalesced / Koatl's Claw
Leader(s)
Saurus Oldblood on Carnosaur 250 points
General
Command Trait: Dominant Predator
Artifact: N/A
Saurus Scar-Veteran on Carnosaur 210 points
Command Trait:
Artifact: Eviscerating Blade
Saurus Sunblood 130
Command Trait: N/A
Artifact: N/A
Skink Starseer 140
Command Trait: N/A
Artifact: N/A
Battleline(s)
Saurus Warriors 40 320
Full Command, Spears
Saurus Warriors 20 180
Behemoth(s)
Bastiladon 2 440
Solar Engine
Batallion(s)
Sunclaw Temple-Host 140
Total: 1990 points
Hello ,
just the general can have a commandant trait , and you have one artefact + an artefact with the batallion so you can take a second artefact ;)
I would consider maybe Aetherquartz Brooch as a second artefact because this list is hungry with CP.
Hello ,
I thought as much, but just wanted to be sure! Should I put the Aetherquartz Brooch on the Skink Starseer?
hm the skink starseer can already generate CP so if he dies when he had the brooch you will not win any CP anymore so maybe it is better to give the artifact to another leader? I do not know
List looks good for friendly play. Bastiladons, however, doesn't fit well. Their laser attack is mediocre without Thunder Lizard's command ability. They will be also too slow to go and tie enemy units. It seems to me, that Koatl's Claw is the worst constellation to take bastiladons.
Not that they are bad or something, but they just don't add anything to your list and you can fill these 440 points with better stuff.
Back
Top
