8th Ed. 2000p vs skaven
Discussion in 'Lizardmen Army Lists' started by steam, Aug 28, 2010.
  1. steam
    steam Member
    lords
    slann
    3 disciplins, bane head
    lore of death
    hereos
    skink chief
    blow pipe
    core
    24 asurus warriors
    spears
    15 skinks
    blow pipes
    15 skinks
    blow pipes
    speacial
    20 TG
    hand weapon and shield, Plague of domination
    10 cold ones
    champ, musucian, horned one
    rare
    4 salamander
    (I will run them by 1)
    total 2005
    Please help me with the list.
  2. Ilnar3
    Ilnar3 New Member
    You can only have 3 groups of sallies,
    So youl have to run 1 group of 2
    You REALY lack bodies,
    Only two blocks in 2k,
    Still,
    You have a pair of anvils and a semi decent hammer,
    I'd be tempted to drop the skink chief. He's not going to do anything against skaven,
    If your opponent fields more than a few jezails, youl be packing up early.
  3. steam
    steam Member
    I could drop the cold ones and take saurus, but I wanted the cold ones for taking out his war mashines.
    Sjowld I change the chief for a mage?
  4. Ilnar3
    Ilnar3 New Member
    I'd take chameleon skinks or terries to kill war machines,
    Cor will kill anything he has,short of a HPA or a doom wheel if they make it into combat.
    But, it will take them forever as he will ALWAYS be steadfast,
  5. Nuclear
    Nuclear New Member
    Actually, you can only have 2 duplicates in Rare, 3 duplicates in Special. So 2x2 for the sallies.
    I'm not sure how you got a horned one on your cold one cav champ, as he cannot take magic items. More importantly, a horned one, if you were to take it on a character, is worthless when he joins a unit. Always move at the speed of the slowest model, I3 vs 2 is not great for one attack, and stupidity is almost not an issue with ld8 cold booded, with an 89% chance of passing it w/o the bsb around, 98.8% with it.
    That said, I think 10 CO is way overkill. Those pts would be better spent on more bodies. Run 5 CO and get 16 more saurus. Much more effective IMO.
    On that note, the plaque of dominion is not great IMO. It's range is really low, and most wizards have a decent LD anyways. I think the pts are better spent somewhere else.
    As for the slann-lore of death is good, but the best spell-purple sun, is not good to use on a slann that will run with TG. You place the template on his base before moving it out, so you are probably going to kill 2-3 TG every time you cast it. Light or Life are probably better. As for the disciplines, I hope you are taking Mystery, Rumination, and Becalming Cogitation?
    I don't think that chief is gonna do much for you. For the same pts you can get 5 chameleons, which are harder to kill, and pump out more shots sooner.
  6. steam
    steam Member
    Nuclear, ok so I will drop 5 cold ones and chief, take chameleon, drop the banner and horned one.
    Maybe I showld take lore of life?
