Didn't know if it was better to make a new post or update my old one so if I did wrong tell me hah Heros and lords: Skink Priest 1 Dispell scroll & diadem of power 1 Ancient steggie 1 Oldblood 1 Carnosaur 1 Blade of revered tzunki 1 War Drum of xahutec 1 Light armor 1 Shield 1 Troops: Skinks 25 Standard Bearer 1 Champion 1 Musician 1 Skinks 10 Saurus 25 Spears 25 Standard Bearer 1 Champion 1 Musician 1 Special: Terradons 3 Cold One cav 5 Standard Bearer 1 Champion 1 Musician 1 Plaque of dominion 1 Rare: Salamanders 3 okay as far as I can tell my friend will be running a necro on a corpse cart inside a big unit of zombies and his vampire lord inside a unit of skellies with a banner of undead legion but not sure if he is taking other magic items. This will be supported by cav of course, dire wolves and I think blood knights and grave guard but no heroes or lords with them. there will also be a varghulf and I think he said he'd try and put in a black coach and some ghouls but not sure points wise how much all of this is. Changes I made from my last army I dropped a terradon and the skink chief on a terra with the plaque of dominion becuase I felt I needed alittle more hammer power from cold one riders. one change I though about making to this list was to shrink the bigger skink squad and take more smaller squads to annoy and block the cav while my main force eats away at the 2 main troops and leaders. I figure if I can blow through his troops and kill his leaders the cav will be easy to mop up. it may seem like a wast but I think I will not rush my stegadon into combat I'll hang back and use the EOTG while marching behind the forces abit and slamming into enemies as needed, if some cav breaks through I'd rather slam the steggie into them then be flanked by them I think. the carnosaur will be the general and be there to do as much damage as possible and provide a cold blooded leadership 9 rally thanks to the wardrum when not if some of my units flee.
Never faced VC but seems like a ok list. personally I would have favored some kroxies and skirmishing skinks to prevent auto breaking agains outnubering fear-causers.. But if you manage to manouver your big saurus block, you should be packed up and good to go
If you give your block of skinks a Kroxigor they're then immune to fear... worth the extra in this case.
Sorry, bad sentence... Kroxies wouldn't auto brake due to that they cause fear themselves. Skinks I suggested in like more of a support to prevent fast cav. to run past em and around your flanks. and I think skirmishers is much better suited to this than cohorts. IMO
