7th Ed. 7th edition 4k lizardmen army
Discussion in 'Lizardmen Army Lists' started by biggreen, Jan 21, 2009.
What four Disciplines should i take?
Poll closed Feb 10, 2009.
  1. Focus of mystery(know all spells in lore)
    7 vote(s)
    53.8%
  2. High state of Consciousness(Only Magic attack effect slann)
    12 vote(s)
    92.3%
  3. Healing(regeneration)
    7 vote(s)
    53.8%
  4. Magic resistant(3)
    6 vote(s)
    46.2%
  5. slann cuase Fear
    1 vote(s)
    7.7%
Multiple votes are allowed.
  1. biggreen
    biggreen New Member
    so went to local GW and sit down came up with this list. i am new to Lizardmen, i need your help.
    Slann with four disciplines and three magical items
    Disciplines
    Magic resistant(3) or slann cuase Fear
    Magical items
    Cube of darkness
    Blood Statuette of spite
    Dispel scroll
    Skink Priest+level2+Eotg+Rod of storm+Ityi Grubs
    Skink Priest +level2 +Eotg + Dispel scroll+ rod of power
    skink Chief+ javlin +Light armour +shield + Magical items
    Saurus warriors- 20 + command
    Saurus warriors- 20+ command
    Skink skirmishers- 11+ Musican
    Skink skirmishers- 10+ Javlin and shields+ Musican
    cold one riders- 15 +command +bearer
    temple guard- 20 +command +burning blade +plague of domination
    Terri Rider- 3 +musican
    Chameleon skink x5 +stalker
    sally hunting pack- 3
    Let know what u think?
  2. callmeHK
    callmeHK New Member
    You know.. I would equip the slann with more than 1 choise. To bad your poll can only accept 1 choise :p Ill just vopte the one i like best.
    wich is ethereal! No more bolt throwers aiming froggy down! no more cannonballs to be catched. The solution is simple. Buy ethereal now! Call within 5 minutes and get magic resistance 3 for only 50 points. This will not only make your slann almost imposible to wound, also the unit he joins gains MR3!! what a great day.. :p
    I think i can join those anoying tv shows.
    Anyway, ethereal and the magic resistance looks the best combo by far to me. Fear doesnt matter for your templys are immune to psych ( i thought they were when joined by a slann in 7th )
    HK
  3. Dalkarius
    Dalkarius New Member
    You need to get rid of the points value immediately, when the mods see this I don't think they'll be happy. Edit your post so you don't show that, it's illegal.
  4. Ninjaskink
    Ninjaskink New Member
    If you take the free die per spell power bonus (which I don't think too many others will skip) then I definitely thiink the regeneration bonus is a must. If you do happen to miscast, you're more than likely going to take some form of hit and/or wound from it and the regen will be a good way to keep the big toad afloat. Combined with the MR 3 and etheriality, this should definitely make the Slann a tough nut to crack. While the Focus of Mystery is certainly nice to fill out the list, I don't see it as completely necessary depending on which lore you're taking against whatever army. And the fear bonus is nice if you want to keep all of those low Ld hordes of infantry blocks (I'm looking at you O&G) from locking up your unit with flank and rear charges. But since most armies will only be sending heavy cavalry or other cream of the crop units to try and break the TG block, it will probably be a wasted effort.
    So to recap (since I didn't get to push the button): MR3, Regen, Etherial, extra power die. You only get 4 or 5 spells from the one lore, but the rest should make sure he's not going to lose out to much of anything.
  5. Dalkarius
    I'm going to take this moment to point out the Slann's ability causes Terror, not Fear.
